Transmission & Drivetrain Gearboxes, Differentials, Clutches
what type of LSD is this?
Old May 8, 2013 | 01:09 PM
angryhillbilly's Avatar
Default what type of LSD is this?
Bought a type r trans. Guy said it was all stock and worked great. Put her in, filled her up with some torco mtf.
And went for a drive and it would clunk very bad around corners. Did a lot of research on what it could be. The possibility of it being a clutch type lsd came up, I did some tests that other threads said and according to them I did not have a clutch type. So to me that meant it must be oem and prolly broken. So I had it swaped out for an ATS clutch type and what do you know I had a clutch type in there the whole time. That had an incorrect ring gear as well. The trans is great now. Proper fluid, normal click/clunk and grips great. But what kind of clutch type lsd did we pull out? Any way to know?
Pics comming in a second
Old May 8, 2013 | 01:16 PM
Default Re: what type of LSD is this?
Old May 9, 2013 | 12:19 PM
any idea what kinda LSD this is? Any idea if there is any way to tell or test?
Old May 9, 2013 | 01:24 PM
parts@synchrotech's Avatar
Looks like a KAAZ LSD unit
Old May 9, 2013 | 01:32 PM
Any way to be certain? I did not inspect any markings anywhere on the unit
Old May 9, 2013 | 01:42 PM
myEKsedan's Avatar
99% sure its a Kaaz unit. One way to check for sure is take a picture of the speed sensor gear and post it up here. The speed sensor gear for the Kaaz diff are different that the stock speed sensor gear. Just sold my Kaaz for that very reason (clunking/uncomfortable). Their really good for Auto X doe...
Old May 9, 2013 | 01:43 PM
myEKsedan's Avatar
Also, the Kaaz diffs like kaaz fluid. helps quiet it down a bit...
Old May 9, 2013 | 01:44 PM
KAAZ units will also have the speedo ring built onto the housing.
Old May 9, 2013 | 01:48 PM
myEKsedan's Avatar
X2
Old May 9, 2013 | 01:49 PM
myEKsedan's Avatar
Are the bolts for the ring gear right hand thread vs the stock left hand thread bolts on a stock differential?
Old May 9, 2013 | 07:00 PM
the bolts are indeed right hand thread.
not sure where to look for the speedo ring. heres some more pics. also i do not have the VSS that goes with it. but the shop did mention that there was an issue with mine with this diff.
Old May 10, 2013 | 04:57 AM
myEKsedan's Avatar
Yep. Looks like a Kaaz to me. The VSS that goes with it is $120 from Kaaz just for the gear. and is smaller in diameter than the factory VSS gear.
Old May 11, 2013 | 04:44 PM
Awsome, thanks. Know anyone thats wants to buy it? Lol its for sale seeing as though I dont need it.
dblair
May 3, 2013 01:21 PM
4.8t
Feb 3, 2010 01:31 AM
SimbaDogg
Mar 16, 2004 07:08 PM
2khb
22
Jun 28, 2003 03:20 PM
Spade
22
Jun 15, 2002 11:39 AM
