throttle cable okay??!?
alright so when i picked up the del sol lsv with gsr head the throttle cable was wrong. so now i finally replaced it with a gsr one. and had to order the gsr bracket. went to go put everything on and realized the throttle pulley isnt the gsr one. as it goes the direction as the colored arrow below. i have it zip tied in certain spots as circled below. it idles normal and dosent fluctuate any. is this safe having it like this? ill run it correctly once i can find a gsr pulley or body for cheap. no bashing please i know i need to do things the right way but maybe this will work. btw the guy who had it before me had it ran the same way but under the manifold instead and using a different cable. his cable was same length but the end that goes into the gas pedal wasnt the big round one. it was identical to the one inserted into the pulley. thanks H-t!
