Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
K-Series!!!!:::J35/J37 TB's, K20A2 Oil Pumps, RRC Intake Manifolds, etc:::
Old May 8, 2013 | 10:12 AM
AFH-Parts's Avatar
Default K-Series!!!!:::J35/J37 TB's, K20A2 Oil Pumps, RRC Intake Manifolds, etc:::
Looking for something different than the RSX setup?
The Accord shifter box and cables can be had very cheap brand new
only $174.99 shipped!! for both in the cont.48
paypal is hondaparts@autofair.com
**please add your screen name and order in the comment box
This is perfect for a custom application or with the Accord,TSX,or Z3 trans.
The Accord box has been very hard to get ahold of and we have these instock!!
- This goes perfect with the K-TUNED Z3 shifter plate kit in EG/DC/EK
Any pins/clips/washers etc... always instock as well. Add a shift **** in for a killer deal , pm me for details.
us on FACEBOOK
We now carry INSANE SHAFTS HIGH PERFORMANCE AXLES
Honda/Acura application with any K-series motor swap. 500whp rated axles. Engineered for all your high performance needs. Race proven on drag and circuit tracks.
Similar to OEM specs but re-engineered to provide the end user with not only a better product but a stronger and more durable CV axle.
InsaneShafts has developed an affordable high quality product for all your racing needs. Whether for drag racing, road racing or daily use, these axles have proven to last.
InsaneShafts has a long history of developing custom CV axles for many off-road vehicles.
This swap axle requires no hub/spindle modifications (even swap axles). It has been designed to give the consumer the best product for the money and have stood toe to toe against all your bigger stage axles.
-Kswap EG/DC/EKK2 32mm axles or 36mm
-06-11 Civic Si 36mm
-RSX-S 36mm
-RSX base 32mm
-Kswap CRX 32mm or 36mm
-94GSR+ Bseries 32mm or 36mm
-01-09 S2000 axles
-Lotus Elise Kswap axles
and many more applications , dont see what your looking for? just ask.
Only $375 shipped per set
K-series 5.07 Final Drive set
FD2 Civic Type R
$449 shipped! instock at AFH
Pay now with Paypal!! please make sure your screen name is in the message box, click and done!
Brand new OEM Honda parts
Paypal is hondaparts@autofair.com
**please add your screen name and order in the paypal comment box
Old May 8, 2013 | 10:18 AM
AFH-Parts's Avatar
Default Re: K-Series!!!!:::J35/J37 TB's, K20A2 Oil Pumps, RRC Intake Manifolds, etc:::
TSX RBB 25* VTC gear
There is alot of new cams out on the market requiring this K24A2 TSX 25* VTC gear, We have had plenty of requests for these. Feel free to use this thread for cam and VTC discussion :up:
$125 shipped brand new!!
**please add your order and screen name in the comment box thanks
OEM HONDA PARTS
We are offering brand new Honda RRC intake manifolds for $449 shipped!!!
We have supplied over 400 RRC's to the K community, We work hard so you can push the limits.
And of course we also have tb adapters or any gaskets you might need with this instock all at the cheapest prices.
These are instock and ships right after payment:up:
**please put your screen name and order in the comment box when paying thanks
We also have the RBC 50* vtc gear also instock same price....
us on FACEBOOK
OEM HONDA PARTS
RRC crank pulley
Brand new and fresh!!
These are literally the smallest and lightest oem K-series crank pulleys availible.
4.4 lbs 5 7/16" diameter
$100 shipped
This is a perfect upgrade on the cheap for you 8thgen Civic Si owners.
The J35 DBW throttle body 68mm inlet
Only $110 shipped with emissions fitting added.
$135 shipped with correct matching P2R thermal tb gasket
-RBC-P157
-RRC-P118
Pay now with Paypal!! please make sure your screen name and which manifold you have is added into the paypal message box
Always instock!! Paypal hondaparts@autofair.com
**please put your username and item in comments on pp
Originally Posted by Holyfa5
I got mine yesterday. These guys are the real deal.. Plus their customer service is awesome... I have officially disowned my local dealership.. I recommend this bolt on to any 8th civic owner... Easy to install and a noticeable driving difference.... Thanks guys and i look forward to doing business with you again....
Anyone ordering a tb please include all order info in the comment box if paying paypal. It's very important. And also which manifold its going on so we ship the right gasket. This will keep confusion to a minimum This also speeds up the process on getting it to you
Great info here...Brand New OEM 68-64.5 mm DBW throttle body Stupid Cheap - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
P2R thermal tb gasket instock $135 shipped with correct gasket
K20A2/K20Z1 oil pump conversion
OEM Honda parts
This is for everyone doing a RSX-S oil pump conversion on your K-series engine, We have what you need here to get the job done :up:
-K20A2 oil pump
-K20A2 baffle plate
-K20A2 oil pump chain
-K20A2 oil pump chain guide
-bolts for the oil pump
-bolts for the baffle plate
-bolt and washer to plug oil jet on the block
-Hondabond
$249 shipped
Pay now with Paypal! Add your screen name in the message box, click and done :up:
We always stock everything for the swap
**please put your screen name and parts info in the comment box when paying**
*bolts not pictured but are included
**If you would also need a K20A2 aluminum oil pan or oil pump chain tensioner, pm me for a price with the kit,also instock**
Brand new JDM OEM DC5 ITR valve cover
-Genuine OEM Honda part
-Classic wrinkle red
-Fits 1st gen Kseries K20A/K24A and K20Z1/Z3 engines
-adds a clean look to your engine bay
$313 shipped
RRC valve covers also available, pm me
please add your order and screen name in the commet box thanks
Brand new Kseries valve covers
Fresh out of the box! Perfect to clean up your engine or send to the powder coater since most cant use some that have seen oil. Let your mind go wild on a blank canvas! Instock ready to ship
K20Z3 RAA valve cover with "HONDA" logo
Fits 1st gen Kseries K20A/K24A and K20Z3 engines
Only $129.95 shipped :up:
Old May 8, 2013 | 10:23 AM
AFH-Parts's Avatar
BNIB RSX-S Denso primary wideband A/F sensors
Just arrived!!
We have these instock ready to ship. This is exactly what you for your Kswap or RSX-S replacement. No more screwing around with malfunctioning sensors or overpaying for one.
Only $139.99 shipped to your door
Brand new USDM 02-04 Acura RSX-S PRB ECU
37820-PRB-305
Perfect for Hondata KPRO upgrade. This is a must have!
$499 shipped
Fast and easy payment with the Paypal feature, click and done!
We have new DC5 Type R flywheel's here. Lightweight plus OEM quality & reliability. Weight 11lbs, ready to ship
$389 shipped!!!!!
Please add your order and screen name in the comment box
us on FACEBOOK
K24A Steel oil pan
-11200-RAA-A00
Intended for the K24A4, K24A8, K24A1, K20A3. Can be used on other Kmotors
Also can be used with the K20A2 oil pump
Only $99.95 shipped!
**On SALE now for a limited time**
** Hondabond also instock and can be added in addition
K-series 4.7 Final Drive set
$299 shipped!!
Wanting to switch to the 4.7 FD?? great upgrade for the 02-04 RSX trans.
This requires bearing 91003-PPP-004 if not installed in a 05-06 RSX manual transmission, always instock $32 in addition
**please add your screen name and order in the paypal comment box thanks
J37 ZDX big bore throttle body only $200 shipped modded for 8thgen!!
This throttle body setup generally for the 8thgen Civic Si owners. This is not recommended for a stock engine setup.
The emissions fitting can be run two ways. The brass NPT fitting as seen on the J35 tb setup or the cleaner look with the plugged with a vaccum T fitting for the vacumn source from the booster port. Please speicfy which you prefer when ordering. Requires the P2R tb adapter for the RBC/RRC. This can be installed on the RBC using the adapter plate as well, but the tb opening on the manifold will need opened up, otherwise it will become a bottle neck
-Inlet ID 78mm
-Outlet ID 70mm
This is very similar and comparable to the TL-SH tb, but easier on the wallet. Requires the P2R adapter setup also. All instock.
http://www.k20a.org/forum/showthread.php?t=105390
Complete ZDX install package $335 shipped!!
--includes the modded tb with both thermal tb gaskets and adapter
P384 P2R Throttle body adapter for RBC/RRC
P118 P2R Thermal tb gasket
P149 P2R thermal tb gasket
RRC manifold with ZDX tb COMBO package $799 shipped!!
comes with everything listed above plus the Thermal P2R Intake manifold gasket and the RRC Type R intake manifold. All instock, ready to use on the 8th Gen Si
P113 P2R Thermal IMG
The ever so popular 410cc RDX injector sets with OEM clips Brand New
$204.99 shipped in the U.S.
Always instock!!
Clockwise Motion Baffle for K20A -K20A2 oil pump/pan setup
$275 shipped instock!! :up:
Works with type-s pump/type-s oil pan
Honda K20A "Easy Fit" baffled sump kit designed to fit inside the factory sump pan without any modifications.
This baffled sump kit is located across the original sump pan inner webs and is sized precisely so that the factory windage tray locks it in place when you refit the sump.
Avoids the need to drill holes at impossible angles or TIG weld to oil saturated aluminium.
A must if you are running a wet sumped K20 in anger unless you have access to a plentiful supply of big ends bearings!
Very High quality piece!
Originally Posted by Mr. Dc5
Yup Right hand turns all my oil would build up on the tranny side of oil pan and my oil pump would suck dry. Sketchy. This baffled pan is so sick. I wouldnt track without one ever again.
Old May 9, 2013 | 10:31 AM
AFH-Parts's Avatar
Up
Old May 14, 2013 | 10:21 AM
AFH-Parts's Avatar
Old May 16, 2013 | 08:56 AM
AFH-Parts's Avatar
Up
Old May 22, 2013 | 10:41 AM
AFH-Parts's Avatar
Bump
Old May 23, 2013 | 09:32 AM
AFH-Parts's Avatar
Up!
Old May 24, 2013 | 10:09 AM
AFH-Parts's Avatar
Thank God It's Friday!
Had my PM's reset, anybody who messaged me in the last 24-48 hours you might want to try again.
Old May 28, 2013 | 08:42 AM
AFH-Parts's Avatar
Up!
Old May 31, 2013 | 07:57 AM
AFH-Parts's Avatar
TGIF
Old Jun 4, 2013 | 08:32 AM
AFH-Parts's Avatar
New week new month
Old Jun 5, 2013 | 08:23 AM
AFH-Parts's Avatar
Happy hump day
Old Jun 10, 2013 | 08:19 AM
AFH-Parts's Avatar
TTT
Old Jun 12, 2013 | 09:53 AM
AFH-Parts's Avatar
Up up and away
Old Jun 13, 2013 | 08:01 AM
AFH-Parts's Avatar
Happy Thursday
Old Jun 14, 2013 | 09:04 AM
AFH-Parts's Avatar
Happy Friday
Old Jun 18, 2013 | 08:50 AM
AFH-Parts's Avatar
AFH is back at it
Old Jun 19, 2013 | 09:24 AM
AFH-Parts's Avatar
TTT
Old Jun 21, 2013 | 09:28 AM
AFH-Parts's Avatar
Happy Friday
Old Jun 28, 2013 | 08:02 AM
AFH-Parts's Avatar
Bump!!!
Old Jul 1, 2013 | 08:17 AM
AFH-Parts's Avatar
TTT
Old Jul 12, 2013 | 08:28 AM
AFH-Parts's Avatar
Bump
Old Jul 16, 2013 | 10:43 AM
AFH-Parts's Avatar
Up for a new week.
Old Jul 24, 2013 | 10:13 AM
AFH-Parts's Avatar
Up
