Transmission & Drivetrain Gearboxes, Differentials, Clutches
Can't install seal.
Old May 7, 2013 | 06:36 PM
tmramsburg's Avatar
Default Can't install seal.
I have a d16 trans that was dropped on the ground. It fell on the 32mm side fill hole. The opening is not a perfect circle and the plug won't thread in. How can I fix this? Heat it up and thread the plug in? Get a tap and re-tap the threads? I have a track day coming up and I don't think the dishwasher discharge hose and a 3/4 inch copper cap jammed into it will pass tech inspection.
Old May 9, 2013 | 05:31 PM
78F350's Avatar
Default Re: Can't install seal.
Since no one else has an answer, try some J-B weld. With enough J-B Weld you can fix anything. Clean it and score it before it goes on. I don't know about the inspection, but if you do it right it will hold and seal.
josephcmiller2
16
Mar 1, 2012 11:51 PM
Charlie Moua
Feb 6, 2011 07:30 PM
MI4$DC5
Mar 11, 2006 07:56 PM
HondaKid99
Jul 24, 2003 08:26 AM
Batoutahell
Jul 6, 2003 01:39 PM
