Ok to just use fuel cut for rev limits and anti-lag
Never had to deal with this before with Crome...but...
When setting up the anti-lag on my car, it was inconsistently building boost with just the "ignition cut". I found that if i just checked the "fuel cut" box it built it more consistently. And was the far more violent popping and banging you normally associate with anti-lag. Just wanted to make sure just cutting fuel was ok for a means of rev limit.
Ignition cut is what works best for anti-lag and as long as you dont live on it, its fine. Fuel cut works for anti-lag but is much harder to control.
When using Fuel+Igntion cut does it actually disable your RPM gauge? I don't see the need for both? I'm also a n00b at "tuning" if you will..
