Valves springs for B16A2
Old Oct 23, 2002 | 08:57 AM
Ek4 B16A2's Avatar
Default Valves springs for B16A2
Hello
What do you advise me like valves springs for my B16A2 ? (Spoon, Mugen, etc....)
I race on circuit and I use CTR cams.
Thank you
Old Oct 23, 2002 | 09:03 AM
WAFFLES's Avatar
Default Re: Valves springs for B16A2 (Ek4 B16A2)
there is no need to rev past 8500with a CTr cam, so factory R valve springs are just fine.(intake only)
[Modified by WAFFLES, 12:03 PM 10/23/2002]
Old Oct 23, 2002 | 09:30 AM
sgT's Avatar
sgT
CTR cams = use CTR/ITR springs
Old Oct 23, 2002 | 11:53 AM
Integ_TypeT's Avatar
Default Re: Valves springs for B16A2 (sgT)
I agree with the earlier posts, If you are not reving above 8400, dont bother with titanium valve springs. Now, if you go ahead and modify your ECU with a re-burn, deifintely go with tit. springs. They will save your engine.
Old Oct 23, 2002 | 01:21 PM
Ek4 B16A2's Avatar
Default Re: Valves springs for B16A2 (Integ_TypeT)
Yes I have got a Mugen ECU with 9000 rev limiter.
In France I know several persons who explosed theirs type R engines because a retainer break down on account of high rpm.
Thank you
[Modified by Ek4 B16A2, 10:22 PM 10/23/2002]
[Modified by Ek4 B16A2, 10:25 PM 10/23/2002]
Old Oct 23, 2002 | 01:35 PM
WAFFLES's Avatar
You could always use a little self control and not rev past 8500. But with Ti retainers, stock type R valve springs will suffice. Just don't rev that high very often. 9k everyday with R springs is not good.
Old Oct 23, 2002 | 01:47 PM
blkDOHCsol's Avatar
New User
just because you can rev to 9k, doesnt mean that you will be making power with the CTR cams that high. I mean if you had the valvetrain capability to rev to 28K, but were running a stock gsr cam, then itd be pointles to string it out.
get ctr valvesprings, and rev to 8500.
Old Oct 23, 2002 | 07:17 PM
Benj's Avatar
Default Re: Valves springs for B16A2 (blkDOHCsol)
I'd go with Todas or Spoon, since you're racing in the circuit, it's better protection in case of a mis-shift or something. You may not necessarily rev that high, but it's just for protection. A friend's EK9 racecar recently blew up because of a misshift, going from 3rd to 4th he accidentally put it to 2nd, he was using mugen valvesprings...
Old Oct 23, 2002 | 08:05 PM
B19CivicHB's Avatar
Default Re: Valves springs for B16A2 (Benj)
If you plan on ever upgrading to more aggressive cams, contact Rocket on this board. He has prototype springs in the works right now that are damn stiff. I think he sells them for $150 a set. Ill have them in my head within a few weeks.
-Nick-
Old Oct 23, 2002 | 09:57 PM
Ek4 B16A2's Avatar
Default Re: Valves springs for B16A2 (B19CivicHB)
Thank you very much for your help.
Old Oct 24, 2002 | 12:24 AM
blkDOHCsol's Avatar
New User
daym..that sux, ive overreved my stock b16a springs past 9K misshifting..happened to me 2x, I was sooo scared-guess i was lucky tho
Old Oct 24, 2002 | 01:34 AM
d0nkeyxPunch's Avatar
Banned
Type R valvesprings with titanium retainers, Type R throttle body and intake manifold should get you to rev to 9K and make power. Don't forget the adj. cam gears too.
1990hondacrx
13
Apr 6, 2009 08:31 PM
Downey
Oct 19, 2003 02:41 AM
Dan1krzysi
Jan 31, 2003 02:57 PM
JeffS
Jan 31, 2003 02:17 PM
qbsi
Jun 15, 2002 01:46 PM
