Sensor I.D.
Old May 7, 2013 | 02:37 PM
UrbanDiplomat's Avatar
Default Sensor I.D.
OBD1 LS Intake Manifold. What sensor goes here?
Old May 7, 2013 | 02:47 PM
B_Swapped93's Avatar
Default Re: Sensor I.D.
the better question is WHAT sensor are you missing if none then i'm not sure. any codes ? looks like the evap soli plug...
Old May 7, 2013 | 06:33 PM
I'm finishing up a b20 swap into my eg. It's not running yet so no codes. I was hoping to square away as much as possible before turning the key. The sensor in question mounts to that 10mm bolt hole on the intake manifold.
Old May 7, 2013 | 06:39 PM
Here is a website that provides great diagrams http://www.acuraautomotiveparts.org/...p/mws/home.jsp just select your year,model,trim
Old May 8, 2013 | 08:26 AM
Creator's Avatar
2 wire? Looks like it is for the IAT intake air temp sensor
Old May 8, 2013 | 08:41 AM
Thanks guys!!
Old May 8, 2013 | 08:46 AM
kyden's Avatar
since it appears your IAT is plugged in, i'd have to say evap purge solenoid.
Old May 8, 2013 | 11:58 AM
Creator's Avatar
Yea, on second viewing I do notice that your IAT is already there. My bad.
ROOSTER.
Jan 31, 2014 05:42 PM
crist488
11
Jul 15, 2011 09:26 PM
madcrossover
Feb 12, 2007 08:03 PM
str8JDMteggy
Oct 23, 2006 12:57 PM
BuddyC
Apr 20, 2004 04:54 PM
