Fuel leak from hardline ? (pic)
This is the hardline that connects to the evap (which I removed) I notice a strong smell of gas sometimes finial caught where it was coming from. what can I do about it I had a bolt jammed in the last little rubber bit but that didn't seem to work appearently. couls use some input as raw gas leaking in a hot bay is kinda scray in the summer also more often than not when I go to fill up on gas I hear this BIG hiss(pressure realease) from the tank when I take the cap off
Im pointing at the line not the heater lever thing
yup I may go get some hose and melt the end together and clamp the part where it connects to the hardline. im pretty sure it's not from the fuel filter as I've never had any trouble with it
hmm any idea what it's called ? im not ripping my line out if it's way back in the tank area. I can live with some gas loss/smell if that's the case. but this is still really strange again there is some SERIOUS pressure behind the gas cap when I open it to fill up.
When I pulled my tank there was a wierd thing attached to it with 2 hoses on it. Not sure what its called bit I think its a combination rollover vent/ return valve thing. If you can't figure it out ill take a pic tomorrow.
that line enters the evap canister. that line is what vents fuel vapor from the tank. do not plug it. you're going to have to live with it or reinstall the canister. that's what it's there for. otherwise, you're just venting into atmosphere.
and the component you're thinking of is the liquid/vapor separator. i know. crazy right? they actually named it by what it does this time
What year is this from? I just removed the canister from my 2000 Integra and I don't remember a line like this being connected to it. Actually, there were only a couple small hoses on it.
mines a 95 idk bout his, but im pretty sure they all have a hardline that runs from the tank to the engine bay. the hard line is then connected to the canister with small rubber hoses.
No, go up with it. Get an axle breather cap(like from the back axle of a pickup). The vent hose needs to be above the fuel level, otherwise liquid fuel(not vapor) comes out. Probably somewhere near the cowl, but not too close to the battery(mixing batt/fuel vapor is no bueno)
some ppl say leave it open other say cap it I never got a real answer when I asked what to do with this line on my old thread on this. if open won't the gas evaporate but if closed(capped) it shoots out !
I thought we had unanimously established this as a vent tube for fuel vapor to the carbon canister. If so, if you put the hose below tank level, liquid gas will naturally siphon out of it until empty. If you mount it above tank level, however, it will vent vapor to atmosphere. That's why your tank is pressurizing, b/c it's not venting w/this hose plugged.
figures
