reading datalogs
Old May 5, 2013 | 10:52 PM
raverx3m's Avatar
Default reading datalogs
is it correct that when datalog shows dropping vacuum number it means exhaust is a restriction.
and when vacuum number goes up towards redline it means the intake system is a restriction.
should map reading curve reflect the torque curve or its not related?
and how to get a better quality logs
i finally was able to do a 4th gear pull hoping this will give me more detailed map curve.
but the rpm and map curves are as you can see not very smooth even in 4th gear
Old May 7, 2013 | 01:02 PM
Bowman's Avatar
Default Re: reading datalogs
INTREESTING
Old May 7, 2013 | 02:05 PM
raverx3m's Avatar
this was on a freeway i finally had a good stretch with no cars and i did from 5000 to 8000rpm in 4th gear.
i did it in 3rd gear last time and couldnt zoom in much at all to see any details so i thought 4th gear pull would bring out more points per minute but when zoomed in its exactly same as 3rd gear pull (neptune)
im still trying to find the cause of that breakdown after vtec the curve is not smooth at all
Old May 7, 2013 | 02:23 PM
TimKennard's Avatar
i've heard pulling more vacuum in upper rpm ranges is a sign of an intake restriction.
as far as exhaust restrictions go, seeing torque fall off unusually early (as in sooner than other engines that are similar) in upper rpm ranges.
take that with a grain of salt though as i have no first hand experience. i am curious what others have to say.
Old May 7, 2013 | 03:18 PM
dellas's Avatar
Manifold pressure readings falling normally indicates intake restriction, exhaust restriction can also affect the intake performance.
Can you email me the datalog.
Old May 7, 2013 | 03:54 PM
Uncle Dave's Avatar
Do you have the log of the AFR's
Old May 7, 2013 | 03:56 PM
Uncle Dave's Avatar
The dyno graph shows it had a ramp rate of 154 it needs to be around 120 to 140 max on a N/A Honda engine.
Old May 7, 2013 | 04:31 PM
raverx3m's Avatar
Thats pretty much the only section that i did a pull.
What graphs u want to see i can make another screenshot with more graphs
And what is the ramp rate?
Old May 7, 2013 | 05:10 PM
Uncle Dave's Avatar
Ramp Rate on a dyno dynamic's is the RPM per sec or distance per sec as they call it, I have been using these dyno's since the early 1990's and all my Honda testing was done and still is on them.
b16a4
Mar 7, 2007 03:55 PM
blackeg
Dec 18, 2006 03:56 AM
bustedasscivic
Nov 16, 2003 09:59 AM
TypeR0149
Mar 19, 2002 02:59 PM
