1993 Accord LX Overheating Issues HELP!!
Old May 5, 2013 | 09:22 PM
rmason1's Avatar
Icon2 1993 Accord LX Overheating Issues HELP!!
I have replaced thermostat, radiator, and have had head gaskets, water pump and timing belt all checked by a mechanic and they said they are good... fans both work but car still wants to run hot. Once hot it cools when i let off gas then gradually climbs sitting still and when i take off again it jumps then cools. I am at a loss for what it is any takers???
Old May 5, 2013 | 10:19 PM
holmesnmanny's Avatar
Default Re: 1993 Accord LX Overheating Issues HELP!!
Idle the car with the radiator cap off and rev it to see if coolant bubbles shoot out of the cap.
Old May 6, 2013 | 06:20 AM
rmason1's Avatar
Is that to check for air in the system? If so the mechanic has gone through the process to get the air out already
Old May 6, 2013 | 10:38 PM
No, you're checking the head gasket for coolant leaks.
But if you don't want ideas, you shouldn't be coming here for help. Just have your mechanic find the problem.
Old May 13, 2013 | 03:50 AM
rmason1's Avatar
If you want to give ideas maybe you should read in the original post the head gaskets have already been checked...
Old May 13, 2013 | 03:52 AM
If he was a legitimate mechanic he would have fixed the issue by now...
Old May 13, 2013 | 09:53 AM
Dirt McHondy's Avatar
C'mon... with the bickering...
Did you try the rad cap thing, though?!
Bilster
Nov 8, 2014 06:58 AM
bobbyisda1
Apr 5, 2009 10:31 PM
discman
Jan 18, 2008 07:56 AM
superstock2
15
Sep 1, 2006 09:44 AM
silinteg90
May 9, 2005 07:56 PM
