1993 Del Sol SI needs transmission
Old May 5, 2013 | 06:38 PM
gazza__8's Avatar
Default 1993 Del Sol SI needs transmission
Hi Guys,
Just checked with my mechanic that I will need to replace my transmission.
I found this online:
http://www.alnjdmautomotors.com/inde...b-d16a-zc.html
Wondering if any of you guys ever bought stuff from them.
Or you guys can point to the right direction.
Thanks!
Old May 5, 2013 | 06:39 PM
B_Swapped93's Avatar
Default Re: 1993 Del Sol SI needs transmission
WHY exactly do you need a new trans ? are you just taking his word for it. needing a new trans in not the most common of things you sure he didn't say/mean clutch
Old May 5, 2013 | 06:47 PM
Former User's Avatar
What are the transmission symptoms?
Old May 5, 2013 | 07:14 PM
gazza__8's Avatar
Noise mainly. I will try my best to describe.
When I speed up, sometimes sounds like some sort of knocking sound(pilot bearing kind), @ about 3000 rpm but it happens at higher rev too. On a good day, it doesn't happen, but it happens quit a lot.
It also happens when I down-shift, similar kind of noise.
Also, when it is neutral, there is something like "ting ting" kind of noise, but if I press down the clutch, the noise is gone.
He said there are couple of the bearing are failing. It is better of the replace it instead of change it. Any thought? Any good place in Seattle I can go to for a transmission inspected? Also, he said I need clutch too.
Old May 5, 2013 | 07:17 PM
Almost sounds like a bad TIB but I could be wrong on that. HMO is a good site from what ppl on here say the sell more than just engines. try taking it some where else first tho
Old May 5, 2013 | 07:33 PM
There's a good DIY in the FAQs sticky for replacing the input shaft bearing. The procedure is similar for the other transmission main bearings.
Old May 5, 2013 | 08:07 PM
gazza__8's Avatar
I tried HMO, but couldn't find the transmission. If I want to upgrade to vtec, what are my options?
What is TIB?
Thanks!
Old May 5, 2013 | 08:15 PM
crazyhouse2011's Avatar
Throw Out Bearing. It was a typo
Old May 5, 2013 | 08:17 PM
What is TIB?
Thanks!
You can put a GS-R(vtec) tranny on a b18b1(non-vtec) no diff the gsr one just feels faster. what engine is in the car tho ? b-series and TIB=throw out bearing
it was an abbreviation.....just like FITV IACV and what not
Old May 5, 2013 | 08:19 PM
jbpnoman's Avatar
VTEC is part of your head, not your transmission. The ISB going bad is extremely common for our transmissions, especially if you're running the wrong fluid. It sounds like your mechanic isn't comfortable actually working on transmissions - just replacing them. If you aren't willing/capable of working on your own car, you should look into finding someone who can actually dig into your transmission. Any used replacement is going to give you the same problems in short time, and any brand new transmission is going to be stupidly expensive.
Old May 5, 2013 | 08:31 PM
This^ fits with a bad transmission main bearing, not a bad clutch throw out bearing.
Old May 8, 2013 | 12:21 PM
gazza__8's Avatar
I am looking to replace myself and learn. How long it take to replace the bearing?
I am looking to upgrade the engine and transmission in the future ( when I save enough money). What type of engine would fit in my Del Sol? Is there any good place I can go and research?
Thanks!
Old May 8, 2013 | 02:29 PM
Emeraldbomber's Avatar
Thanks!
Start your own thread.
Old May 8, 2013 | 02:38 PM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
It is his thread.
Old May 8, 2013 | 02:42 PM
Ohh mann, haha. Sorry OP! dyslexia got me good that time. If you browse around in the hybrid forum youll find a lot of usefull information. The ISB bearing change isnt all that difficult if youve pulled transmission before. If not Dseries.org has a good write up on it.
Old May 8, 2013 | 09:24 PM
jbpnoman's Avatar
We have a good write-up here, as well. Even better than both, though, is the FSM. As long as you have an eye and mind for perfection (tolerances are important), you can do it. First ISB I ever did was actually a full bearing, seal, and synchro replacement, and it took me roughly 8 hours once I got the transmission on blocks. It's definitely a weekend project.
Old May 8, 2013 | 09:48 PM
gazza__8's Avatar
Thanks for the info!
Sounds good to me. Time to do more research. Thanks!!!!
jcd95EX's Avatar
If it was the throw out bearing the sound would not go away when the clutch pedal was depressed. It sound to me like it is most likely one of the bearings in the transmission. Iwould replace the bearings because like someone said a used transmission could end up with the same problem shortly after putting it in.
Old May 8, 2013 | 10:45 PM
gazza__8's Avatar
Make sense! How many different type of bearing I should replace?
Thanks!
Old May 8, 2013 | 10:49 PM
jbpnoman's Avatar
I would look into replacing all of the bearings and seals in your transmission. Your synchros wouldn't be a bad idea, either. With the amount of time and work involved (the ISB is basically the last thing you can remove from the transmission), might as well do it all preventatively.
alloutEVO
28
Jan 28, 2013 04:07 AM
eclipsed95
Apr 23, 2008 01:13 PM
Apocolipse269
Sep 12, 2004 11:45 AM
pcaceres
Jul 6, 2004 05:17 PM
drunkenmonkey
Jun 30, 2002 11:03 AM
