90-93 oem integra seat belts in 94-01 integra?
I have a 96 integra with tan interior that i just converted all to black interior. I found some 93 integra black seat belts that i need to finish my interior, will this work in my 96 integra or no? i tried to search but didnt have much luck.
Should fit just fine the seat belt compatability list is pretty big I have EL belts in my 94 GSR
I'm not familier with the DA tegs. I would assume you'd just lose that feature just as if you convert to a manual steering rack you lose the PS but that would obv be done AFTER the delete of the PS....you know what I mean lol
all da belts have the motorized ones, unless your talking about the lap belt ? theres also the canadian versions which werent motorized . correct me if im wrong about this . but i really wouldnt know how they would even work together ??
B_swapped is from Canada. That's why he doesn't know about the motorized belts. They were a US only thing IIRC.
OP if they are the motorized belts then no, they def wont work. If they're not motorized then compare the buckles. If they're the same and the bolts line up they should work fine.
USDM 1990-1993 integra's had motorized belts. ONLY usdm had the motorized belts. OP, if you're in the states, no, DA belts will not work in a DC integra. If you're not in the states, then yes, they should work fine I believe (BUT don't quote me on that, I'm unsure if the actual belt retractor mechanism that fits in the b-pillar will work in the DC integra)
