d16y7 timing belt replacement
Old May 4, 2013 | 05:15 PM
Lizardslap's Avatar
Default d16y7 timing belt replacement
d16y7 1996 del sol
Ok so I need to verify some things before I button everything back up
when I took off the crank pully the timing mark on the crank is exactly lined up with the arrow on the block
the cams Up arrow is facing exactly down with both marks on the sides (still sits like this nothing has been moved)
my question is can I rotate my cam gear counter clockwise until I get to tdc 1 (of little bit of looseness in all the rockers)
as for the crank how do I know when its at tdc for #1 if its mark is exactly lined up would that be tdc4 its currently set at?
sorry if I wrote some confusion but I am confused by this
turboedsupe
Sep 19, 2008 04:32 PM
91 ZC hatchback
Feb 27, 2006 10:52 AM
MugenHonda
Mar 8, 2005 12:41 PM
nfinitecc
21
Nov 28, 2004 02:22 PM
sivik2nr
May 29, 2003 09:30 PM
