odds of a cracked block H22A4
This is my third time replacing the bearings. This time I had blocked off the oil squirters. New pump,gaskets, crank machined, new bearings. Everything miked twice. yet got it running today but as soon as I got it hot on a drive, oil light came on at idle (new sensor)also have test gauge in engine compartment . Oil pressure was normal for 30 mins before drive (17psi) off idle all the way to 80 psi. I have yet to get this engine right since I got it back from goldeneagle(no more then 300 miles). Is it possible the block could have a crack that only shows up when the block is hot? Could goldeneagle damaged it while milling?
Have you cleaned out all of the oil passages in the main caps and gridle well?
From what I remember you were running balance shafts as opposed to the delete right?
what shape is the oil pickup and pan?
Ya I've gone through a few sets of BS now along with the BS bears. This last time I again replace both. Oil pick up is new , as well as the pump. The pan is stock with a return fitting for turbo that I blocked off since last time my turbo got fried. Passage wise I made sure that when I installed the new BS bearings that the small hole was in the right place as well going through the rest of the oil circuit. The past few days I have driven my car til the light comes on. I can keep the REVs high enough to keep the light off. But it seems its like clock work. Once the engine (which BTW runs extremely smooth ) runs for 45mins to an hour the light comes on. Before that pressure is normal. I figure it has to be the block aluminum has a crack in the oil circuit that only shows up when the block gets to a certain temp.
