full size rad
Old May 4, 2013 | 01:03 PM
dseriesboulder's Avatar
Default full size rad
im looking to get a full size rad. I pulled ac off my 98 and have a big spot id like to fill.
What radiators will fiut in a 98?? I've searched online but can't really find a comparison. Did find one for head lights tho..lol
Anyway, a shop has one in the denver metro area for 50$ but its off a 01...accord maybe..idk.
I've felt bad all day and was just wandering. Thanks
Old May 4, 2013 | 01:13 PM
grumblemarc's Avatar
The Grumpiest
Default Re: full size rad
A full rad just for cosmetic purposes? Not needed. It won't just bolt in.
Old May 4, 2013 | 01:17 PM
it is kinda for cosmetic purposes, but want a full size rad keep the car running cooler??
Will a turbo fit with a full size rad?
edit: its a 02 civic sedan EX
Old May 4, 2013 | 01:25 PM
The Grumpiest
For what? I'm boosted. Where do you see a full sized rad under my hood? Bigger is not always better.
If it's an '02 you're in the wrong forum.
Old May 4, 2013 | 01:27 PM
the radator im looking at is from an 02 but its going in my 98.
So a half size rad is just as good?
Old May 4, 2013 | 01:55 PM
datbumper's Avatar
There's no way you need a full-sized radiator. Even full on track cars use half-sized radiators without any problems. A half-sized will be more than enough. If it's just for cosmetic purposes... sure I guess. I wouldn't though.
Old May 4, 2013 | 02:56 PM
Ok. Just thought with more space for cooling, it would keep it a little cooler. Idk.
Thanks
Old May 4, 2013 | 06:51 PM
datbumper's Avatar
Another thing. An engine has temperatures at which it functions optimally at. Too cold and you're just hurting ****. Too hot, and well... you know that's not good. That's why alot of people are against things like keeping the fan on all the time. Colder's not always better.
Old May 4, 2013 | 06:56 PM
maurouen's Avatar
It's about how much you'd have to pay for it.
Old May 4, 2013 | 09:04 PM
Makes sense.
Old May 4, 2013 | 09:14 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
thats what the thermostat is for, a bigger radiator is more efficient, the engine maximum temp is determined by a lot of factors including the radiator itself, having a bigger one increases the volume of coolant in the system, which can make for a more stable temp, the thermostat only determines the lowest temp the engine will run at, thats what a lot of people dont understand, so they try to take it out, most of the time the thermostat is wide open, it also acts as a restrictor for the coolant, if it flows to fast through the radiator, heat wont be transferred efficiently
Aftermath_Hatch
Nov 17, 2011 10:04 AM
typeeg
Honda Motorcycles
Aug 16, 2004 08:53 PM
ski_rebel_3
Honda S2000
Oct 5, 2002 02:28 PM
RedHatch
Audio / Security / Video
Mar 24, 2002 02:39 PM
