O2 sensor
Old May 4, 2013 | 07:56 AM
gitarman2's Avatar
Default O2 sensor
Was looking around under my car today when I noticed this. Is there a reason that only 3 wires are connected and not all of them?Name:  oVxkmZ0.jpg
Old May 4, 2013 | 12:21 PM
gitarman2's Avatar
Default Re: O2 sensor
It would probably help to mention the reason I was even looking is because I got 2 o2 related codes. First is A/F sensor 1 heater system malfunction (P01135). Second is Secondary Ho2S12 circuit heater malfunction (P0141). I assume the first code has something to do with how the previous owner wired this. The second code is just because there is no second sensor plugged in.
Old May 4, 2013 | 05:32 PM
xile6's Avatar
Well you found your problem.
The o2 sensor is 4wire setup. 2 grounds and sensor out and heater 12volts.
Connect that wire and maybe it will clear out the first light.
If it was me i would get the right connecter and wire it in better.
Old May 10, 2013 | 06:52 PM
andyz's Avatar
Or hope it doesnt ever rain again.
JoshJosephKeith
May 4, 2009 04:38 PM
randomracing
Dec 26, 2008 08:37 AM
CereaLand
Jun 30, 2004 12:01 PM
scrubachu
Jul 30, 2001 04:24 AM
