1990 Acura integra DA with b20 Idling really hight
Old May 3, 2013 | 07:37 PM
Stanleysteamer's Avatar
Icon3 1990 Acura integra DA with b20 Idling really hight
Hi I have a DA with a b20b converted mostly to obd1 but it Idols at 2300 rpm which is really strange I converted the injectors to obd1 and altinator and got a jumper harness , did the dizzy conversion and now it had no spark like WTF I'm totally lost and need help
Thanks Logan
Last edited by Stanleysteamer; May 3, 2013 at 07:39 PM. Reason: Didn't do the right thing for my email Notifications
Old May 3, 2013 | 07:40 PM
B_Swapped93's Avatar
Default Re: 1990 Acura integra DA with b20 Idling really hight
So...how is it starting of it has no spark or has that just started to happen now ? when the car is running check for any vac leaks then/or try this http://www.team-integra.net/forum/bl...peed-gen3.html
Old May 3, 2013 | 07:42 PM
I bought it and it Idoled really high so I parked it and desided to change the throttle body and just little things likes this , then I saw the kid didn't convert the dizzy or anything so I changed that now I have no spark at all
Old May 3, 2013 | 07:45 PM
but if it work and you were getting spark WHY did you change it over the conversion harness is supposed to take care of that now you have another problem. can you convert it back can't fix the idle issue till you get the car going again.
Old May 3, 2013 | 07:57 PM
I think I could but then wouldn't the obd0 not make it run proper like it would run really high and when ever id stop at a stop sign it would die then start again but would run really high again
Old May 3, 2013 | 08:01 PM
ya that's not cause of the dizzy not being converted...put it back get the car running then you can start trying to fix it. but it sounds like a vac leak to me.
Old May 3, 2013 | 08:21 PM
All the vac lines were the same as all the other da's iv looked at
Old May 3, 2013 | 08:34 PM
that doesn't mean one isn't cracked or there's isn't a leak else where
Old May 4, 2013 | 01:26 PM
Brand new lines and still
Old May 4, 2013 | 06:58 PM
sw20 ant's Avatar
What ecu are you running, you shouldn't need to swap it over to obd1 for any reason other than better ecu and injector selection.
check your idle screw, IACV, all vac lines and the FITV! did u replace the intake manifold?
Old May 4, 2013 | 07:00 PM
sw20 ant's Avatar
I'm having the same problems as you are having and you can see it here in my thread I also made a couple videos of how my car idles and things that change it.
My IACV (idle air control valve) is bad and I have to block off the FITV because It's useless and also bad.
https://honda-tech.com/forums/acura-integra-6/b20b4-91-teg-obd0-few-ecu-codes-possible-timing-issue-3140363/
Old May 4, 2013 | 07:03 PM
maurouen's Avatar
I can't decide which is worse.
Old May 5, 2013 | 08:28 AM
marazaii's Avatar
i had similar problems, replaced vac lines and helped some, burp your coolant, might have air trapped in the system.
72Gremlin
Engine Management and Tuning
Dec 15, 2012 08:02 PM
efcivic317
Dec 14, 2011 12:49 PM
dreadhead89
Dec 7, 2009 06:05 PM
Cimburke23
33
Sep 1, 2006 05:59 PM
brent_G
24
Mar 21, 2004 07:07 AM
