Honda S2000 Honda S2000
lights go out whenever i turn or hit a bump.
Old May 3, 2013 | 11:20 AM
eg6islife's Avatar
Default lights go out whenever i turn or hit a bump.
I got a buddy who has an s2000, and hes having trouble with his lights. he says that it doesn't happen all the time but if it does its when he hits a bump or turns. im not to sure i asked if he had HIDs and he doesn't that car is all stock. i checked to make sure the lights were plugged in all the way, and looked at the grounds right there under the hood on both sides. ive never got to really play with s2000s so i figured id ask you guys maybe you guys know where to look or to start?
Thanks
Jason.
Old May 4, 2013 | 06:30 PM
go-part's Avatar
Default Re: lights go out whenever i turn or hit a bump.
Check to make sure the battery terminals are clean and the cables are firmly attached to the terminals.
Old May 5, 2013 | 02:09 AM
Boots's Avatar
s2000's come stock with HID's...check all the connections to the bulb and ballast
Old May 5, 2013 | 12:06 PM
eg6islife's Avatar
I did check the battery terminals but ill check them again to make sure.
Old May 5, 2013 | 12:08 PM
eg6islife's Avatar
Yeah i was just informing as if they were not after market ones knowing that they always go out when wiring problems. Where would the ballast be? Ive never been under the hood, yet. so I just wanna make sure I know where im looking.
Thank you guys
Old May 5, 2013 | 04:12 PM
Boots's Avatar
take wheels off, take front fender liner out and its all right there
Old May 5, 2013 | 06:00 PM
eg6islife's Avatar
thank you! ill take a look!
Bikerxgames420
Sep 3, 2007 11:24 PM
PinoyCivic
Mar 4, 2007 11:38 AM
anomale
Nov 30, 2005 01:00 PM
ewing86
Sep 30, 2004 05:49 PM
SeaBass
Jul 1, 2003 06:10 PM
