TN: Cannot pass emissions Stock 1994 Civic CX
Hey so I cannot pass emissions on a 1994 Civic CX with the stock D15b8 engine and transmission.
So I have changed the Cap, Rotor, Wires, O2 Sensor, Coolant Temp Sensor, inspected the Exhaust (Found out the cat was gutted before I got it), new spark plugs (checked gap), Adjusted ignition timing, Adjusted Timing belt. Checked everything 3 times.
I really don't know what else to check. Any one else have this experience?
my test values
508 HC (Max 220)
13.1% CO2 (Max N/A)
0.86 CO (Max 1.2)
I was told that the car should be able to pass emissions in Tennessee without a Cat.
Aside from that the car smells like its running very rich. I just can't figure out why. I know I don't have a Cat but putting a cat in won't really help with the high HC very much. I think it's just running way too rich and I don't know why. I'm thinking the Fuel Pressure regulator may be the cause but I am out of ideas. Any help would be greatly appreciated!
my test values
508 HC (Max 220)
13.1% CO2 (Max N/A)
0.86 CO (Max 1.2)
One of the main purposes of a cat is to convert unburnt fuel (hydrocarbons) into CO2 and water so that alone is going to reduce your hydrocarbon levels and is probably a good reason why it "smells" like is running rich..... Unburnt fuel is coming out the tail pipe.
If it is running rich though a few things you can check or is a stuck or leaky injector, clogged air filter, bad MAP sensor, bad ignition coil. Those are a few good places to start.
X2 above post. Put a high-flow cat back in it(then you'll pass) they're about 120ish After install. You'll get mileage And a tiny bit of power back that you are losing from running rich.
Ok. I'm working on getting a Cat. If anyone has one they want to sell me, please chime in. Its the type that bolts straight on to the manifold.
What I don't understand is why are people are saying it can pass without one?
If you loved me, you'd all sell me your magic cards to me today
Yeah I understand what you mean or cars wouldn't have them in the first place. What puzzles me is that people tell me that they were able to pass emissions in TN without a Catalytic Converter. Either way I'm going to put one on, not trying to get around that. The car stinks and I want to fix that.
It's running very rich. I don't think the lack of a cat alone could explain all those hydrocarbons.
Any CEL codes thrown? Is there an exhaust leak in the header near or upstream of the O2 sensor?
I'm wondering if the injectors got changed to larger ones. I heard somewhere that the CX and VX Civics used slightly smaller injectors (~180-190cc) and the DX, Si models (~240cc). So maybe the injectors when before and a previous owner changed it to the wrong ones. Or like I said, Fuel Pressure is too high. I'm going to check the vacuum and fuel pressure with a gauge when I get a chance to rule that out.
Plus, running rich could destroy a Catalytic Converter fairly quickly as well.
Is code 6 still thrown?
The O2 sensor is sitting right outside the exhaust ports so even with a small leak its unlikely that it would cause a huge problem.
A bad ECT sensor or circuit would definitely make the engine run rich. Which ECT sensor did you replace? Your engine has three. The ECT sensor related to code 6 has nothing to do with the temp gauge in the cluster.
Even a small exhaust leak in the header could make the engine run very rich.
It's worth figuring out what injectors are installed.
Checking the fuel pressure is also a good idea.
No question about it.
I am going to check for exhaust leaks again as well as fuel pressure and vacuum. And double check those injectors.
- The 2-wire sensor is what would throw code 6.
- The 1-wire sensor is for the temp gauge in the cluster.
There is one ECT sensor that plugs into the thermostat housing. It has 2 wires and controls the radiator fan.
There are two ECT sensors that plug into the block under the distributor:
A vacuum leak won't make the engine run rich.
I'm going to check on those injectors, vacuum leaks, and Fuel pressure when I get a chance.
The car runs good, idles smooth and quiet, has decent pick up as far as what you'll get from a 70hp engine.
Google how to cheat emissions, super street did a great write up a few years back there are a couple tricks you can do but you have to have a cat
Some one told me an 1/8 of a tank of gas + 99% isopropyl alcohol would do the trick. He said its pretty much fool-proof. But there is a crooked smog guy out here I heard about. I'm just not sure how reliable that info is. These places are not like California where they are privately run. The emissions places are run by the state.
Just fix the problem the right way so the engine runs properly. Then enjoy the long term benefits, such as good gas mileage and the cat no dying soon after installation.
