A/M Drag Car F20B Opinions/Suggestions
This is my first time building an all motor engine, so I would like some opinions and suggestions on my setup.
-Stock Bottom-end
-Kaizenspeed Balance Shaft Removal & Manual Tensioner
-Ported Head
-Supertech Springs & Retainers
-Skunk2 Pro1s
-Ported Lower P13 Intake
-QSD H2B Kit
-GSR Transmission w/ mFactory LSD
Unsure about the following:
-I would like to do the upper intake maninfold like "nah2b", coming up above the engine, but I am unsure of what throttle body size?
-Stock injectors, rdx, or bigger?
-Arp Head Studs necessary?
-Header?
-Maybe a small jet wet direct port nitrous system?
I'll post some pictures of the car and parts later.
-Stock Bottom-end
-Ported Head
-Skunk2 Pro1s
-QSD H2B Kit
-Header?
-Stock Bottom-end
-Ported Head
-Skunk2 Pro1s
-QSD H2B Kit
-Header?
-Stock Bottom-end
-Ported Head
-Skunk2 Pro1s
-QSD H2B Kit
-Header?
and thats with the small motor
stock bottom end with RSX pistons
Custom IM
we have 2 sets of custom 15.1 arias pistons that should be going in soon and also a new cylinder head thats flowing 330. The header is a bisi knock off we have a 90mm tb
here is a pic
LMK if you got any more questions
Your best bet for power and to be competitive I would recommend the below upgrades.
F23 Crank and Rods, K20 pistons, 12-1 compression, 87 bore
I run an f20b and in stock displacement its doable but its hard to get the short track down.. i think it can be competitive at higher displacement levels. Im at around 1900lbs
-Stock Bottom-end
-Ported Head
-Skunk2 Pro1s
-QSD H2B Kit
-Header?
-Stock Bottom-end
-Ported Head
-Skunk2 Pro1s
-QSD H2B Kit
-Header?
we have a F2B all motor car made 275hp and ran 7.1 in the 1/8th thats all we got in SD
Custom IM
here is a pic
Custom IM
here is a pic
I am trying to keep it simple and stay all motor. I will try the f20 out for this season or until it last then I will upgrade to somethingbigger.
i meant we also have a head that flows 330 it is currently not on the car neither is the bigger bottom end
