93 civic SI A/C block off
Just swapped a B18C5 in my 93 hatch.
Ditched all the A/C parts, but I'm left with a large opening up front beside my radiator.
Pretty sure I've seen condenser block off plates on other models that came without A/C.
Part number?
How is it mounted?
Part number?
How is it mounted?
I appreciate the help, unfortunately that's not the part I'm looking for.
The part I'm talking about mounts behind the front bumper right beside a half size radiator, basically taking place of the A/C condenser.
Right now you can see into where my header is exposed.
I have personally never seen this factory honda condenser block off. I thought the non a/c civics just had an opening there.
I removed my a/c and i bought the a.c button block off that goes on the climate control and cant figure out how to remove the a.c button so i can pop my block off button in place.
I fabbed one bc my builder/tuner did a pressure test and said to much air was going around the radiatior instead of threw it and was causing to much pressure in the engine bay for air to properly flow threw the radiatior. I also have a front mount intercooler also tho.
my 94 lx came with a factory piece of plastic next to the radiator.
http://www.hondaautomotiveparts.com/...y5=ENGINE+HOOD
Its #14
Its #14
Its #14
Its #14
93 Eg Couper
Jan 2, 2009 06:20 PM
CO_CReX
Apr 29, 2007 06:44 PM
