Turbo D!!!!! Build Thread
Old May 1, 2013 | 09:52 PM
based13's Avatar
Icon6 Turbo D!!!!! Build Thread
So over the next 3 months I will be building a turbo b7/z6 mini me, The plan is to shoot for 260-280 hp with reliablity as this will be my daily/street car. I know the term budget build gets thrown around alot on ht but I plan to do this build for cheap without sacrificing too much reliability, I will do my best to list prices for parts as I update the build, the ultimate goal is to keep the motor rebuild under $1500.
Old May 1, 2013 | 09:57 PM
based13's Avatar
Default Re: Turbo D!!!!! Build Thread
So I picked up a full b7 swap out of a 94 dx for $250, the motor has 230xxx on it, but I wont know the condition of the block untill I open er up.
Old May 1, 2013 | 10:23 PM
slowDB7's Avatar
what are your plans for rods, b7 rods are good for about 200 hp
id say try cx racing rods, http://www.cxracing.com/mm5/merchant...Category_Code= with arp bolts
Old May 2, 2013 | 03:24 AM
apexi_rsx's Avatar
its a d15 i wouldnt bother opening it up unless it needs it ..... if ur not upgrading rods and this motor doesnt smoke then just boost it as is if all u want is a boosted stock block...
Old May 2, 2013 | 05:12 AM
nealnanoHX's Avatar
Dam that motor looks in rough shape. I would not boost a motor with 230K on it and expect it to live long. At least do a bottom end refresh and refresh the head as well. But you might as well put forged pistons and rods in it if you are going that far.
Old May 2, 2013 | 05:40 AM
based13's Avatar
after much research and consideration i think i will be going with the cx racing rods although they may be considered ebay parts, they do do extensive research and testing, plus they make pretty good coil overs, and for 230 bucks i cant say no, this is a budget build, the crower billet i beams just arnt worth it to me, i could go the route of machined ls rods, or b16 rods with 1g-gte pistons, but i dont trust the machines shops around me with that custom fabbing
Old May 2, 2013 | 05:45 AM
based13's Avatar
I a upgrading internals, i have a 1500 budget just or this, the only thing that im keeping on the b7 is the block, crank, and a few other things, the rest of the parts off the motor I can sell or scrap, to make some money back
Old May 2, 2013 | 07:21 AM
slowDB7's Avatar
if you get the cx rods, let me know how they work
i want to boost my b7 soon
Old May 2, 2013 | 07:28 AM
Emeraldbomber's Avatar
We can tell this is a budget build.
Old May 2, 2013 | 08:32 AM
EFSedan#6's Avatar
Wooo! Budget build. In for the updates.
Old May 2, 2013 | 08:54 AM
bumpstick's Avatar
What turbo/mani are you planning on using?
Old May 2, 2013 | 10:24 AM
based13's Avatar
No idea yet, any suggestions, not trying to break the bank
Old May 2, 2013 | 10:29 AM
based13's Avatar
Picked up a d16z6 (si head) for 40 bucks!!!! has everything but the vtec solenoid, pretty pumped about it this is a deal in my book.
slowDB7's Avatar
nice pick up on the z6 head
also what tranny are you going to run with the setup
Old May 2, 2013 | 10:35 AM
apexi_rsx's Avatar
so are u building this yourself or what? i hope u know getting ANY H beam rod the block needs knotched and so does the girddle with ARP rod bolts...
Old May 2, 2013 | 10:49 AM
jbpnoman's Avatar
Any Mitsubishi turbo would work well, especially a 13b, 15g, or 19t. I personally have a 19t and love it. I also have a 13b laying around, with a manifold. If you're interested, shoot me a PM.
Old May 2, 2013 | 10:51 AM
MiNeSEK's Avatar
In for updates as well. Good luck on your build!
Old May 2, 2013 | 12:19 PM
based13's Avatar
thanks, but i want to build the engine b4 i decide what turbo set up i want
Old May 2, 2013 | 12:21 PM
based13's Avatar
i will be doing the majority of the build my self, any machine work will be done at my friends shop, they build all my crews motors so I trust them, plus Ill get a nice hookup on the price
Old May 2, 2013 | 12:22 PM
based13's Avatar
^^^^ and i thought the block only had to be notched when using the ls rods, either way its no biggie, its a shame that i cant get my hands on some fjt rods
Old May 2, 2013 | 01:42 PM
d16tof22's Avatar
Good luck with the build! Some advice on the turbo: go big if you're looking for upper 200 whp. I had a reliable turbo y8 for about 10 years. I had Eagle rods (which I notched the block for using a dremel tool); so it's not hard to do at all provided that you keep all the metal dust out of the engine. My turbo was a GT32 - 60/48. Not huge, but I was running 17psi on 93 octane making about 290whp.
I would get at least a T3 ish sized turbo if you can; my 15g was good for only 185whp at 12psi, then ran out of breath.
Old May 2, 2013 | 02:11 PM
based13's Avatar
^^^^^ thanks ill consider this when im turbo shopping in the near future
Old May 2, 2013 | 02:15 PM
based13's Avatar
im a bout to start breaking down the b7, fingers crossed that the cylinders held up after all those miles
Old May 2, 2013 | 03:59 PM
based13's Avatar
si tranny, i can get them for relativley cheap around me (120-150), but maybe a gsr or b16 later down the line, still gotta research d2b ive seen it done before
Old May 2, 2013 | 04:03 PM
Eddie's Avatar
Master Ninja
Love budget builds good luck op
