95 Civic won't start
Old May 1, 2013 | 04:01 PM
cdovenbarger's Avatar
Icon3 95 Civic won't start
So drove my 92 civic si with a d15b vtec engine to my friends house to swap (d15b vtec) to my 95 civic dx. D15B vtec engine ran great when i dropped it off. My friend did the swap but the car will not start. The 95 civic used to be a at but he switched it to a mt. If i spray carb cleaner into the throttle body it will stay running but as soon as i stop it dies. Fuel pump primes. There is spark. and now the battery is draining. My boyfriend said it's the starting system? Also when my friend did the swap he melted the throttle body cable due to the starter shorting out. I replaced the starter. All the fuses are good too. Can any body help me please. Also have tried two different ECU's, there was not a change.
Old May 1, 2013 | 08:30 PM
Former User's Avatar
Default Re: 95 Civic won't start
Check whether all 4 fuel injector clips get battery voltage with the key in ON(II).
Old May 7, 2013 | 11:44 AM
They all get voltage. The fuel pump is on till the car dies too. When the guy tried to start it the first time the starter shorted out causing the throttle cable to melt. I'm wandering it it could have screwed up the wiring?
Old May 7, 2013 | 11:49 AM
Not sure how the throttle cable would melt. I think you mean the large starter wire attached to the hood fuse box.
Yes
Old May 7, 2013 | 12:00 PM
No it was the throttle cable. It actually melted to the bracket and i had to buy a new cable and bracket and a new starter for that matter. I can keep it running if i spray carb cleaner in the trottle body. I'm really sorry if i sound stupid too i just don't no where to begin if the wiring is jacked.
Old May 7, 2013 | 12:02 PM
Melted throttle cable? Did the engine overheat?
If the fuel pump primes, check whether the fuel injector clips get battery voltage.
mx249
Mar 11, 2013 02:59 PM
dalebly50
Feb 26, 2012 01:52 AM
lilshady6796
Aug 17, 2009 04:58 PM
SoHc Ej1
11
Jul 18, 2007 08:45 AM
