Oil in Throttle Body/Air Filter
Old May 1, 2013 | 03:13 PM
nrraiders35's Avatar
Default Oil in Throttle Body/Air Filter
I was looking for the cause of my excessive oil consumption on my 2001 Accord and noticed a large amount of oil residue on the the throttle body and Air Filter hose. The inside of both seemed pretty clean but there was oil caked on the outside. What does this mean? thanks
Old May 1, 2013 | 04:46 PM
charliccs's Avatar
Default Re: Oil in Throttle Body/Air Filter
I don´t think that could be the cause a oil consumption...
I think you need to clean your engine...
look down the engine and see if theres some leak or turn on the engine and see if blue smoke is coming from the exhaust...
Old May 1, 2013 | 05:05 PM
That is the only spot on the engine with any oil residue. It doesn't leak any at all. WHy would there be oil in that spot?
Old May 1, 2013 | 05:07 PM
mesrop1991's Avatar
Is it burning oil? If you floor it and look in the rear view mirror, do you see a cloud of smoke?
Old May 1, 2013 | 05:34 PM
yes there is blue smoke over 5500 rpm's
Old May 1, 2013 | 07:09 PM
nus_dogg's Avatar
Clean it with brake cleaner and keep an close eye on it to see where it would seep.
Old May 1, 2013 | 10:46 PM
holmesnmanny's Avatar
What does the inside of that intake hose look like ? The part closest to where it is showing oil
Old May 1, 2013 | 11:12 PM
The inside of the intake hose is clean. It looks like the guy I bought it from just changed the air filter too. Idk why oil would build up in this spot
Old May 1, 2013 | 11:30 PM
I suppose that rules out pcv issues. You know what that could be is a leaking transmission seal and as the fluid leaks and the axle spins it's slinging oil up there. Just a guess tho. You're going to have to clean it up and do a test run to see where it's coming from.
Old May 6, 2013 | 06:02 PM
mesrop1991's Avatar
http://www.autoguide.com/auto-news/2...aust-mean.html
GUNNER666
Jul 12, 2004 08:10 AM
2stockrocketz
Apr 13, 2004 09:22 PM
SLeePeR012
Jan 20, 2004 08:03 AM
KiDSoL
Acura TL, RL & ZDX
Jan 4, 2004 12:09 AM
Benjamin Tang
Nov 5, 2001 04:48 AM
