Honda CR-V & Element 2WD & 4WD Element & CR-V
98 CRV head gasket
Old May 1, 2013 | 09:23 AM
narc32's Avatar
Default 98 CRV head gasket
Recently did the head gasket on my 98 CRV. now I have a small oil leak between the head and the block around the timing belt area I had to head checked for compression and shave down at the machine shop. I have a feeling the head bolts must be re torqued. do I have to drain all fluids from the engine before loosening and retorqing or can I just loosen and re tightened without draining fluid?
Old May 1, 2013 | 10:39 AM
Barbera13Racing's Avatar
Default Re: 98 CRV head gasket
the only problem i see you runing to is the coolant running into the oil and rest of the engine, i would change the oil anyway since its under the wrench, you can always drain the antifreeze below the head level
Old May 6, 2013 | 07:43 AM
narc32's Avatar
ok so in the process of re doing the head gasket, when i a see a crack in the piston sleeve. A very small crack at the very top of the sleeve(probably why i had to change the gasket)the machine shop i took the head to quoted me an outrageous price on rebuilding the block, so i was wondering if i can replace my b20b4 block with a b20b block and if i can what modifications do i have to make for it to run properly? any help is appreciated thanks also my b20b4 engine runs on synth blend oil if i go with the b20b block can i still use the old head since i know its good?
Old May 6, 2013 | 08:19 AM
EsotericImage's Avatar
Retired Moderator
yes, use your existing head and you will need a new headgasket as well.
Or you can just buy a new B20 engine and swap it in. theyre only 550 before shipping.
Old May 6, 2013 | 09:47 AM
Oh the cracked Sleeve situation, Luckly i cought mine before it cracked amd got a cylinder support system done. since you most likely need new sleeves
http://www.goldeneaglemfg.com/index....page=page&id=1
But basically any B series Block should bolt up to existing mounts
A B20Z is the update for 1st gen 98-2000 and is higher compression and your stock head should work on that too
Old May 6, 2013 | 10:19 AM
dogbiscuit's Avatar
I recently bought a B20B 99-00 from hmotors. I think it ended up being around 950 shipped
Old May 6, 2013 | 12:13 PM
Retired Moderator
The only way you would crack a sleeve is cause of detonation. Honda B20's are fine under NA conditions and can hold boost as well.
If you have a cracked sleeve, either you had some bad gas, or some mis-fire goin on. IDK what type of abuse the engine has had or why the HG blew in the 1st place.
Honda P75 heads are the wost flowing head of the Bseries family. While sourcing a P8R can be done (as it flows close to a B16) if your looking for more performance. Milling the head .020" will also bump up the compression. Its not the proper way to bump compression, it is the simplest.
Old May 6, 2013 | 03:25 PM
narc32's Avatar
i just found a b20b engine for 200 bucks looks exactly the same looks like everything will line up no problem are there any hidden issues i should look for or any difference between my b20b4 and the b20b?
thewrai6th
Oct 12, 2009 03:45 PM
I8ayellowcrayon
18
Jan 29, 2004 11:42 AM
ITR_1211
Jan 5, 2004 09:04 PM
R6Elmo
Nov 13, 2003 04:47 PM
