p1768 tranny code
Old May 1, 2013 | 08:10 AM
ef-b16sedan's Avatar
Default p1768 tranny code
Car info first
I have a 2000 civic ex auto,I had to replace the Tranny due to the last owner driving over a curb and cracking the transmission housing. I didn't notice if there was a code before the replacement or not. I know the new Trans was from a 96 and was in good working order before being swapped for a manual Trans. After putting the new Trans in the D4 light was on right away. After the install I found out my buddy who helped with the install never filled the torque converter before installing in the Trans. I checked the thought the flow chart from alldata and I come up with nothing. My question is can I get this code from a low fluid level? IM topping off fluid now and probably going to recheck the flow chart to make sure I didn't miss anything. Any help would be great
Old May 4, 2013 | 12:56 PM
go-part's Avatar
Default Re: p1768 tranny code
http://www.2carpros.com/questions/ho...ord-code-p1768
Old May 4, 2013 | 03:23 PM
94EG8's Avatar
Seagull Management
If the transmission happened to come from anything but an EX you'll get codes, but it shouldn't throw a P1768. Did you try swapping out the linear solenoid over from the old transmission?
chill841
Jul 30, 2014 06:39 AM
tei344
Nov 9, 2008 12:40 PM
md23vtec
Jul 24, 2003 09:11 AM
