b16a engine questions
Old May 1, 2013 | 12:08 AM
Xanthias's Avatar
Default b16a engine questions
Hey guys so I've been researching for 2 hours before posting my questions so please do not bash me for not searching before asking. Anyways I just pulled a b16a obd2 second gen out of a canadian 99-00 sir. My first question would be whether or not that is a swap. Everywhere I looked it says that those engines are from jdm sirs or jdm del sol. This was a left hand drive canadian sir. The head is stamped with the year 94 but is obd2 so when i researched, apperently the jdm second gen is obd1... I've found a few sites regarding transmissions and I have an s21. 3 sites told me it is a non lsd trans, and 1 site said it was an optional lsd and is a jdm trans basically same as usdm b16a2 y21. Can someone shed some light on these questions or give me some links to point me in the accurate direction? Thanks
Old May 1, 2013 | 12:16 AM
jbpnoman's Avatar
Default Re: b16a engine questions
The S21 transmission is for the Del Sol VTEC, as well as the 99-00 Civic SI.
If it's OBD2, It's a B16A2/A4. The CDM SiR is the USDM SI, so it should be a B16A2. Double check the block stamp. A 94 stamped head means it came from a 95 car, which would mean it's OBD1. Double check your block stamp. It could be from a SiR-II B16A, B16A2, or B16A3.
Old May 1, 2013 | 12:36 AM
Xanthias's Avatar
The block stamp is b16a i cleaned it and rechecked it and blinked twice haha I'm confused as hell because the car is 99-00 and it has a p2t ecu which i cant find any info on... Is it possible that someone swapped a obd1 engine into a obd2 car? I think i have a couple pics
Old May 1, 2013 | 01:22 AM
HondaPartsHero's Avatar
Technical Hero
P2T is the stock 99-00 SI/SIR ECU. More than likely someone blew the stock engine or it was stolen and the owner bought a JDM replacement.
Old May 1, 2013 | 01:46 AM
jbpnoman's Avatar
It's pretty simple to swap an OBD1 engine in an OBD2 chassis, especially if they're basically the exact same motor.
Old May 1, 2013 | 10:40 AM
Xanthias's Avatar
It's illegal so I didn't really consider but yea that could be it. I'll clean it up today and check all the stamps again.
Erik_Pb_Foot
22
Feb 6, 2015 11:50 PM
JJGL-EF90
10
Feb 7, 2010 06:16 PM
-JSpecEk*9-
11
Jul 23, 2005 10:56 AM
Spade
15
May 29, 2002 02:31 PM
B18CHatch
Oct 22, 2001 01:03 PM
