b16a engine questions
Hey guys so I've been researching for 2 hours before posting my questions so please do not bash me for not searching before asking. Anyways I just pulled a b16a obd2 second gen out of a canadian 99-00 sir. My first question would be whether or not that is a swap. Everywhere I looked it says that those engines are from jdm sirs or jdm del sol. This was a left hand drive canadian sir. The head is stamped with the year 94 but is obd2 so when i researched, apperently the jdm second gen is obd1... I've found a few sites regarding transmissions and I have an s21. 3 sites told me it is a non lsd trans, and 1 site said it was an optional lsd and is a jdm trans basically same as usdm b16a2 y21. Can someone shed some light on these questions or give me some links to point me in the accurate direction? Thanks
Re: b16a engine questions
The S21 transmission is for the Del Sol VTEC, as well as the 99-00 Civic SI.
If it's OBD2, It's a B16A2/A4. The CDM SiR is the USDM SI, so it should be a B16A2. Double check the block stamp. A 94 stamped head means it came from a 95 car, which would mean it's OBD1. Double check your block stamp. It could be from a SiR-II B16A, B16A2, or B16A3.
The block stamp is b16a i cleaned it and rechecked it and blinked twice haha I'm confused as hell because the car is 99-00 and it has a p2t ecu which i cant find any info on... Is it possible that someone swapped a obd1 engine into a obd2 car? I think i have a couple pics
Erik_Pb_Foot
22
02-06-2015 11:50 PM
JJGL-EF90
10
02-07-2010 06:16 PM
Spade
15
05-29-2002 02:31 PM
