cruise control help
Ive searched this but wasnt able to find any help.
I travel quite a bit and just relocated my battery and fuse box to inside the car. Was curious if anyone else relocated there c/c to were the battery sits on there ek. It would be similiar to the CD accords set/up. Would i be able to just extend the lines and mount it over there? I want to clean up the engine bay and be able to keep my c/c for my trips to memphis. do you know of anyone that has done this?
Any help is appreciated
You weren't able to find anything because it is totally impractical idea and ill-thought out. What purpose would this serve other than a cosmetic one? The battery I can understand.
Can it possibly be done? Sure. I'd like to see how you plan to extend the cable that attaches to the pedal.
you're correct it is cosmetic. i thought since there's that extra room where the battery used to be why not try it. Thats why i was curious if anyone has done it. There are a few cd accords in the local pick'n'pull i'll have to go and grab the cable for the pedal and see if it is compatiable. If all else fails ill just keep it where it is or remove it completely.
