Back purging and weld cosmetics
Old Apr 30, 2013 | 02:35 PM
PhilStubbs's Avatar
Default Back purging and weld cosmetics
Does back purging benefit the look of the weld on the outside at all, or does it just keep the oxygen from getting to the back Sade of the weld? I don't want to waste argon practicing if it won't affect the top side
Old Apr 30, 2013 | 06:29 PM
boostedb20z's Avatar
Default Re: Back purging and weld cosmetics
not that ive seen from my welding if your just practicing i wouldnt purge
Old May 1, 2013 | 06:13 AM
PhilStubbs's Avatar
That's the answer I was hoping to hear. Tig welding already uses so much more gas than mig, dumping it into the pipe for no reason seems like such a waste.
Old May 1, 2013 | 10:46 AM
vtechjunkie's Avatar
It wont make any difference in the top of the weld, unless you are welding a butt/fillet joint on some thin material, and fully penetrating. Then you might see some contaminants in the puddle. For practicing my timing and bead aesthetics, I use a 8ga steel plate, and stack beads that way.
Old May 1, 2013 | 12:57 PM
redboost10's Avatar
It's not a waste. For cosmetic purposes yes it's a waste.
Old May 1, 2013 | 04:31 PM
PhilStubbs's Avatar
I understand the benefit in strength, just wasn't sure if contaminants would get through the the top side
Smashback
Welding / Fabrication
Dec 11, 2012 11:18 AM
_k20a2_
11
Jan 2, 2008 10:04 PM
TurboEM1
Mar 11, 2006 08:46 PM
Flashmn
Oct 31, 2005 03:44 PM
5thgencivic
Mar 18, 2005 12:36 PM
