B16 Block Problem(Stroker Related)
Hey fellas,
Here to ask a question for a friend of mine(he doesn't know English). We are having a hard time in our setup.
b16 block
b16 head
b18 crank(89mm)
84mm sleeves with
84mm CP storker pistons
We are using the OEM B16A2 rods. The problem is, rods hit the sleeves when we install them.
"Why is that ?" is the question. Hope you fellas can help me out.
Thanks in advance...
b16 block
b16 head
b18 crank(89mm)
84mm sleeves with
A 5-second search yielded this.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/95mm-crank-gsr-block-common-notch-3141729/
How much searching did you do before posting?
Yes, safe to grind and then deburr (make smooth by removing sharp edges) the bottom of the cylinders.
Thank you very much, we indeed will grind the bottom end of the sleeves a little bit. This was a first for us, that's why it suprised us a bit. But, thanks to this epic forum that we have learned what to do.
Sorry for the lack of searching on my part but believe me i couldn't see anything so i opened this topic. So, sorry for the inconvenience.
PS: Sorry for the bad English.
when i was looking for answers on this topic all I could find was aluminum rod situations which makes sense you'd need to notch. i thought something was wrong because i have tons of room around my setup.
Good luck keep us posted.
1QwIkEf
Mid-Atlantic (Sales)
May 10, 2007 09:15 PM
