Speakers not working
So the other day I took out my subwoofer in my car. now the front speakers don't work when the rears do. I checked all the wiring and theres no problem. Before i took out the subwoofers, both front and rear worked fine.
Any ideas?
Any ideas?
If f possible try to hook up speakers to the leads immediately out of the head unit. Rule out wire without having to get into the doors. It may be a bad head unit. I had one that just decided it only wanted to drive the left rear and the sub.
Like when a girlfriend calls cuz her car won't start and you get there to fix it and its because its in drive. ( true story )
Happens more then you think, without more info from OP, my second guess would be, there is a 4ch amp, fronts on two channels, the other two channels bridged "mixed mono" for the sub, the rear speakers are off the HUs internal amp 4ch amp, [rear channels].
The off board 4ch amp is not working, either damaged or off.
Third guess, both front speakers are blown.
I would assume OP has checked all the obvious possibilities.
OP said, "I checked all the wiring and theres no problem" that is kind of vague, and he may have checked all the wiring, but there is definatly a problem.
Without more info, that's all I got. 94
Jose-aka-Pedro
Audio / Security / Video
May 15, 2006 11:20 AM
