need help identifying these cams
Old Apr 29, 2013 | 11:40 PM
STOCK_SOHC_DX's Avatar
Default need help identifying these cams
kinda strange with the in and ex markings since the dizzy key way is there.
Old Apr 30, 2013 | 10:33 AM
Rocket's Avatar
Default Re: need help identifying these cams
The cams look somewhat beefy. Do you have any measuring tools? Such as dial caliper.
Old Apr 30, 2013 | 07:19 PM
yeah I can post some measurements when I have time. funny this whole time I thought this motor was stock so the ecu was chipped to itr spec and seemed weak.
Old Apr 30, 2013 | 10:44 PM
Rocket's Avatar
Hard to tell with any confidence,but the cams look like they have some meat on them. If you can measure the distance between the nose and heel of the lobe, we'll have more info to go by.
Old Jun 17, 2013 | 02:44 AM
I got 3 measurements
33.10 mm
36.81 mm
35.13 mm
Old Jun 17, 2013 | 10:20 AM
Rocket's Avatar
Vtec has an estimated 11.3mm lift ((36.81mm - base circle 29.5mm)*1.55).
I would guess CTR.
Good job on measuring.
Old Jun 17, 2013 | 10:26 AM
JuggerNaut-CTR's Avatar
The end of the exhaust cam looks like a 95-00/97-99 itr cam.
Easy way to tell oem cams is by the ends
Old Jun 17, 2013 | 10:58 AM
I would guess CTR.
These gotta be some kind of replicas because of this strange intake and exhaust markings. As for the measurements I got really lucky
It's not oem since it doesn't have the "rings" on the key way side and the strange casting marks.
K24allmotoreg
Jan 28, 2015 04:40 AM
92db2gs-r
Feb 27, 2011 05:00 PM
Weel
Sep 6, 2010 04:48 PM
Grip
May 14, 2004 08:16 PM
