valvetrain clatter on b16?????? help
i have some funny clattering noise coming from sounds like the head, but its wierd because i just had my valves adjusted after hearing the noise and its still rattling. I replaced the timing belt and the timing belt tensioner and every little thing i can think of. I mean its not affecting performance just that the noise is annoying and make me a little worried..
Thanx
Thanx
If you replace your motion assembly, that will take care of the clatter. I've never replaced one before so i cant help you with the "how to", but I know this will eliminate the noise. I'm having mine replaced though on my GSR head...but after replacing cams and internals.
I dont think its the LMA's but could be. First check out all your bolts and nuts and make sure they are all tightened down the spec. I had the same thing happen to mine and it was about a month after the valve adjustment. Took it to honda to find out what the problem could be and they said it was my cam sproket bolts where not tightened down all the way. So those started coming loose and my cams sprokets started to wobble
Myechtatel
Honda CR-V & Element
Apr 15, 2015 05:01 AM
vlc92189
Mar 30, 2007 10:14 AM
