How are the Toyo Ra-1s? How much do they cost also?
Old Oct 23, 2002 | 12:26 AM
2001TypeR's Avatar
Default How are the Toyo Ra-1s? How much do they cost also?
The above question.....how are the ra-1's in 205 50 15 and how much they cost a piece US?
Old Oct 23, 2002 | 06:49 AM
6ghatch's Avatar
Default Re: How are the Toyo Ra-1s? How much do they cost also? (2001TypeR)
They go for about $130-$140 each. I've never used them but have talked to a few that have. From what I've heard they have very consistent grip, last fairly long, and one of the easier R compounds to drive. They are molded at 8/32 for wet but most will shave them to 4/32 for dry track. I met someone who autocrosses them in full tread but had some serious chunking problems.
Edit: I was thinking of buying these tires for HPDE's earlier this year then realized I should wait until I get more experience with steet tires. R compounds don't give any audible feedback when pushed to the limit.
[Modified by 6ghatch, 11:13 AM 10/23/2002]
Old Oct 23, 2002 | 07:10 AM
bus stop's Avatar
Default Re: How are the Toyo Ra-1s? How much do they cost also? (6ghatch)
anyone had use RA-1 for autox ?
Are they good ? and how they compare to VictorRacer ?
Old Oct 23, 2002 | 07:14 AM
BlueR's Avatar
Default Re: How are the Toyo Ra-1s? How much do they cost also? (George Knighton)
What's your intended use for these tyres?
i'm guessing he wants to use it to go straight
by his comments here:
https://honda-tech.com/zerothread?id=313869
[Modified by BlueR, 11:22 AM 10/23/2002]
Old Oct 23, 2002 | 07:21 AM
Hracer's Avatar
New User
[QUOTE]how are the ra-1's in 205 50 15QUOTE]
I drove just on that size RA1 at a spec miata race a couple of months back.
The RA1 is a great tire. It is virtually right up at the performance level of the hoosier, but the toyo lasts a lot longer and also does not fall off in grip as the hoosier does. For ultimate grip (and feel) you can’t beat a brand new hoosier, but you can certainly come close (if not match it) with a shaved RA1 for use in dry conditions. I have nothing but good things to say for this tire.
Old Oct 23, 2002 | 07:28 AM
Back in Black's Avatar
Rather OG
Default Re: How are the Toyo Ra-1s? How much do they cost also? (Hracer)
Have you used them full-tread for rain use?
Old Oct 23, 2002 | 03:06 PM
2001TypeR's Avatar
Default Re: How are the Toyo Ra-1s? How much do they cost also? (BlueR)
Yup
Old Oct 24, 2002 | 03:46 PM
2001TypeR's Avatar
What do you mean by "shave" them...how do you do that...also which would be cheaper the Ra-1, or the T1-S....
Old Oct 24, 2002 | 04:26 PM
StageOne's Avatar
The RA-1 is a race compound tire, they wont last long on the street maybe a couple thousand miles if you are lucky. The T1-S is a performance street tire. Big difference.
Don't get the RA-1 for the street.
Old Oct 24, 2002 | 04:31 PM
Big Phat R's Avatar
RA-1s have a 40 treadwear rating. A032Rs have an 80 treadwear rating. Most passenger car tires have 250-280 treadwear rating. They are an R compound tire and not recommended for street use.
I have used them and so far they are my favorite tire. They come at 8/32 tread depth and are ideal for rain use at that tread depth. In the dry you will find them very squirmy until you get to 4/32 tread depth (this is the shaved depth). They grip like crazy when up to temperature. They do need quite a bit of heat in them before they start to feel "strong". And they last and last until they cord.
I highly recommend them for track racing/HPDEs/Solo 1.
Old Oct 24, 2002 | 04:37 PM
2001TypeR's Avatar
Default Re: How are the Toyo Ra-1s? How much do they cost also? (Big Phat R)
K thx guys...
Snafu-Si
Aug 27, 2014 10:22 AM
Brandon Clifton
16
Jul 14, 2003 05:05 PM
Spade
61
Oct 1, 2002 02:09 PM
cjb92
May 16, 2002 04:31 AM
ek6-crvtec
17
Apr 11, 2002 04:41 PM
