quick wiring/electrical question. pics inside
Old Apr 28, 2013 | 06:59 PM
Coopa B18c5's Avatar
Default quick wiring/electrical question. pics inside
Hello, ok ill get right to it. i purchased my 98 integra already with a b18c swap done.
Whoever wired the car must of been A. drunk B. high as hell or C. just didnt know what he was doing.
I'v been slowly rewiring the car and SOLDER EVERYTHING BECAUSE ALL THE WIRES ARE JUST TWISTED TOGETHER. and i finally came upon the main emgome harness inside the engine bay and there are a few of these "bigger" wires with either one wire connected to it or a few wires coming out of it. i want to redo them but im not sure if these 'bigger" wires are OEM spec or a handyman special.
don't want to just start cutting stuff without knowing if i can easily resolder them or not.
so just let me know what you think they are!
the top and bottom ones only have one wire atached to it and the middle wire has about 3-4 wires coming out. the bigger wires are gray. thanks
Old Apr 28, 2013 | 07:08 PM
Default Re: quick wiring/electrical question. pics inside
I kind of sliced it open a bit to see what was inside and i dont know if you can tell by this photo but the blue wire goes all the way into the gray wire and the metal of the gray wire goes around the blue wire and out the end where the two are "connected"
confused.....
Old Apr 28, 2013 | 07:10 PM
B_Swapped93's Avatar
What area are those wires going to ? don't think that's oem looks like a little wire shoved to a big one no electrical tape even. does that gray one go all the way to the firewall ?
Old Apr 28, 2013 | 07:26 PM
Its apart of the main harness that comes out of the firewall under the battery. and it did have grayish electrical tape on them. those bigger wires go all the way through the harness towards the firewall as far as i can see them.
its the harness that im holding in my hand
Old Apr 28, 2013 | 08:07 PM
Blackhalo6's Avatar
Those are shielded wires pretty sure they have to be oem don't think drunken stupor guy would have repinned connectors and used shielded wires. My wife's da had some but my 95 gsr didn't so I can't be certain.
Old Apr 28, 2013 | 08:50 PM
yeah the more i looked at it the more they seemed to be oem. just bc of the amount of work it would of taken to do that. still is weird how there's just exposed wire inside of that right? seems like a mess inside of those shielded wire.
Trust me, with the amount of just down right awful wiring in this car its easy just to blame him when i see something "odd" retaining too electrical haha
But its all getting slowly fixed up to how it SHOULD of been done
Old Apr 28, 2013 | 08:58 PM
mr.beeks's Avatar
it looks like a conversion from auto to stik and those cables went into d tranny solenoids
Old Apr 28, 2013 | 09:33 PM
Blackhalo6's Avatar
The raw metal wires inside that sheath are the shield. Its to shield the other wire from emi like from the secondary ignition
Old Apr 29, 2013 | 07:05 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^, they are OEM, and as mentioned they are shielded leads, the shields are grounded at a common ground point.
Shielded leads are used in both auto and manual transmission cars. 94
Old Apr 29, 2013 | 10:37 AM
Thanks for clearing that up for me guys!
Big help
mikej94civex
Jul 11, 2010 04:18 PM
cehcivic15
Feb 8, 2009 09:43 AM
CRXBart
16
Jun 19, 2006 08:53 PM
CivicMike
Jun 27, 2005 07:18 AM
FastNFurious
Jun 14, 2003 06:42 AM
