92 integra gsr- HELP ASAP
Old Apr 28, 2013 | 06:20 PM
easternda9teg's Avatar
Default 92 integra gsr- HELP ASAP
hey guys im new to this site. i joined the site in hopes someone on here can tell me whats wroung with my car. To start off i have a 92 integra gsr(b17a1).
I took the motor out over our winter (nova scotia). did the headgasket, studs, and a clutch. Got the motor back in and got it running but it had a engine code. solved the engine code back to vtec solinoid plug not being fully clipped. Then let it sit for a day or two till i got back at it. started it up and was running good, engine light was off. the only light on was abs and that was on when i parked it. Then the hazard light indicators came on in the dash and it was like the whole car lost power. Right boggy to give it any throttle and then eventually shuts down.the The only thing that gets power when the harzaed lights come on is the hazard lights in dash, everything else shuts down(coolant temp,radio,all switches, heater, like everything) Its something wierd that i never encountered before. Any help at all is appreciated as im stumped. I have done research but came up with nothing along the lines that im looking for.
Remeber i had the motor out so idk if something plugged wroung or not but just clueless on where to look to solve this. thanks for your time and im hopeing to hear from someone who might have an answer. thanks. i took a video on my phone of what it does but not sure how to get that on here.
Old Apr 28, 2013 | 07:12 PM
fcm's Avatar
fcm
Old Fart
Default Re: 92 integra gsr- HELP ASAP
Check your maun grounds, batt. the chassis, [under batt. tray], chassis to engine, [bracket on transmission]. 94
Old Apr 28, 2013 | 07:28 PM
S2BumpsticksGSR's Avatar
X2- your grounds are probably goofy. Don't forget the valvecover ground...
Old Apr 29, 2013 | 06:23 AM
thanks guys il try that today and let you know how that goes.
vlads92gsr
Jun 19, 2013 02:17 PM
b18option
Apr 30, 2009 01:35 PM
