93 civic distributor wiring help
Old Apr 28, 2013 | 05:26 PM
Heemi.v8's Avatar
Icon2 93 civic distributor wiring help
hey there,
new to the forum just have a question for someone in the know.
i have a 93 civic si. but someone swapped it to the d15b7. so i blew that up in january. now i got hold of a d15b from japan im guessing. some one has put a new distributor on it cos all the wires are clean and the housing is shiny.
so the problem im having is that my wiring harness in the car has two plugs and the new distributor has only one.
the colors match except i have one extra blue wire on the cars wiring harness.
does anyone know where this distributor would be from and how i can connect it up? thanks
Old Apr 28, 2013 | 07:30 PM
Heemi.v8's Avatar
Default Re: 93 civic distributor wiring help
so ive done some research. the part was bought off ebay.
http://www.ebay.com/itm/ws/eBayISAPI...m=350777372443
looks like that is the right one for a 99-00 civic sohc? does anyone know if it will work or should i get a new one? (the right one)
Old Apr 29, 2013 | 04:05 AM
94EG8's Avatar
Seagull Management
If you still have your old distributor you can just use that. The blue wire is for the tach signal.
Old Apr 29, 2013 | 04:29 PM
Heemi.v8's Avatar
dont have my old one anymore. sold it with the parts car to a guy who wants a spare shell for his race car.
so in the 99 version what colour is the tach wire? if i had a wiring diagram for the 93 and a wiring diagram for the 99 then i could make it work right? any one got info where to get these diagrams? cheers
Old Apr 29, 2013 | 04:39 PM
94EG8's Avatar
Seagull Management
There isn't one, '99 - '00 models (except HX) get their tach signal from the ECU. If you remove the cap and rotor and the plastic cover underneath you'll see an empty terminal on the igniter/ICM, this is where the missing wire goes.
Old Apr 29, 2013 | 04:48 PM
Heemi.v8's Avatar
fricking legend mate just saved me 3-400 bucks! wahoo!
Old Apr 29, 2013 | 05:07 PM
Heemi.v8's Avatar
btw i like your avatar. yeeeha
Old Apr 29, 2013 | 05:37 PM
94EG8's Avatar
Seagull Management
Apparently that's a real BMW promotional shift ****. Near as I can tell most or all of them were mounted on some sort of paperweight type thing.
Old May 18, 2013 | 04:08 PM
Heemi.v8's Avatar
Hey,
Just another question. seems my timing is way out now. and ive ran out of adjustment. i had a mechanic check it over and he says everything is fine in the cam timing etc just need more adjustment on the distributor. is that a known problem when doing these conversions? im out 10 degrees still. car is running ok but the mechanic said he rotated the distributor 10 degrees more then vice gripped it and took it for a drive and it ran with alot more power.
Old May 18, 2013 | 05:24 PM
nub's Avatar
nub
Hey,
Sounds like the service check connector isn't being jumped which is needed to adjust ignition timing.
Old May 18, 2013 | 08:15 PM
Heemi.v8's Avatar
sorry to be a pain but i dont really know what im doing in this department. any chance you could explain a little further?
Old May 19, 2013 | 11:18 AM
nub's Avatar
nub
Look at the top of this sub forum, the dark grey threads marked "stickies".
The third on down is called "Frequently Asked Questions". Click on it and browse around.
This came out of that section.
http://i639.photobucket.com/albums/u...cture_3679.jpg
Old May 20, 2013 | 04:16 PM
Heemi.v8's Avatar
so there is no difference in casting that would make the newer obd2 distributor not work? i cant find any info on this.
and i think the mechanic that did the timing did jump this connector as he left it hanging out from under my dash thanks
Old May 20, 2013 | 04:33 PM
94EG8's Avatar
Seagull Management
D15B7/D15B8 distributor housings are identical to D16Y7/D16Y8 housings when comparing the bare housing. If you're running out of adjustment either the 2 wire connector isn't being jumped, or the mechanical timing is off.
Old May 20, 2013 | 05:22 PM
Heemi.v8's Avatar
weird. will have to dig deep and probably learn something haha
jj17
Jan 11, 2014 11:01 AM
88LsRex
May 21, 2013 02:23 PM
cfwthb_94
Apr 21, 2009 07:29 AM
m0nee
Jan 24, 2008 02:09 PM
honda2race
Nov 12, 2003 06:46 PM
