My turbo h22a set up
My h22a turbo set up , LOOKING TO MAKE 550+hp give me some updates on what you think please , and THANK YOU! (:
Block/trani:
mahle pistons 9:1 comp
eagle rods
ACL Race Bearings
Stock crank shaft
Pro series synchros
Head:
Skunk2 Pro Stage 2 Cams
Skunk2 Pro Dual Valvesprings and Ti Retainers
Skunk2 Pro Series Adjustable Cam Gears
ARP headstuds
stock valves
Cometic Head gasket
stock intake manifold
stock throttle body
Fuel work:
rc1200cc injectors
stock fuel rail
fuel pressure regulator
255 walbro
regular pump gas
Turbo setup:
gt35 garrett
3 inch down pipe
44mm waste gate
4 bar map
aem tru boost controller
Block/trani:
eagle rods
ACL Race Bearings
Stock crank shaft
Pro series synchros
Head:
ARP headstuds
stock valves
Cometic Head gasket
stock throttle body
Fuel work:
rc1200cc injectors
stock fuel rail
255 walbro
regular pump gas
Turbo setup:
gt35 garrett
3 inch down pipe
44mm waste gate
4 bar map
Last edited by 97sir-tturboh22; Apr 28, 2013 at 01:11 PM. Reason: forgot the question
Its actually not a stock intake throttle body its and 70mm , and im wondering what do u think about the set up let me no what u think it would make at how much psi and blah blah blah ..
Lil Krayzee
Jan 12, 2009 06:42 PM
civic-si-2000
Apr 3, 2004 09:05 AM
