Best wideband to use..
I currently have a Aem wideband and after tuning my car yesterday it was reading way richer compared to the wideband for the dyno pack. The dyno packs wideband was reading 12.1 and 12.2's why my aem was reading 10.8 10.7's so I'm wondering what everyone is using and what would you recommend. I know everyone is gonna have there own preferences but would like to hear what you guys are using and what you have had luck with in your builds thanks.
The closer the better however the closer you get the hotter the O2 sensor will also get which will decrease the life of the sensor. Typically you want it around 18" away from a turbo(with a standard O2 sensor bung). Was the dyno wideband just stuck in the end of a tailpipe or dump tube? Was it actually installed into a bung? Was there any flanges in between the AEM and the dyno wideband?
Are you sure you did not have an exhaust leak before the dyno O2 sensor? That will definately throw off the readings. If you can get it back on the dyno I would swap the two sensors position and see if anything changes.
Since it is most likely not on the dyno anymore pull the O2 sensor and check it to make sure it isnt covered in oil or dirty. Try installing the sensor in the sencond bung and see what the numbers do.
Westrock2000
Feb 25, 2002 05:20 PM
