CEL code 15 for stalling 93 Accord
Im getting a 15 CEL code (Ignition Output Signal) on my 93 accord that continues to stall out on me. I had already replaced the main relay, fuel filter and coil. Any suggestions for my next step?
It's very self explanatory. You just need to take the distributor cap off and there are small screws holding this thing in place. I would just ****** one from a car in the junkyard if you got one nearby.
Before you remove the distributor, make a line with a sharpie across the distributor housing to the cylinder head so that you can put the distributor back in the same exact spot. If you don't do this you will need to redo the ignition timing.
