Cracked skunk2 cam gear
Well it finally happened to me..
After being on the dyno for 3 hours, we dicided to start cleaning things up and getting ready to up the boost and see what she puts down, when all of a sudden you hear this crack noise, followed by a flying bolt out of the bay.. Luckily enough we turned it off right then! after that happened we looked around and noticed 3 bolts were missing out of my exhaust side and it was cracked. We did a leak down and compression test both came out just fine. we then changed it out with one of the cam gears they had at the shop, and it fired right up.. So lucky..
After reviewing the cam gear and hearing everyone's horror stories, the cams seem to be flawed looking at the bolts they use not going all the way thru the cam as well as the mounting surface... they took the surface away to add the con-caved look. after reading most of this from 00b18b(member here) i can really relate to what he said about them..
With that being said the car is fine but need new cam gears and am wondering what you guys recommend and I'm leaning to bisimoto, golden eagle, TODA, Or AEM what are your guys thoughts and opinions?
Really looking for something that isnt gonna slip and have the peace of mind knowing it wont slip in the future.
Thanks
Jason.
Thanks
Jason.
If you want an idea look at this. this is pretty much what happened to me..https://honda-tech.com/forums/all-motor-naturally-aspirated-44/skunk2-pro-series-camgear-failure-2661164/ other then the fact he got his replaced and ive had mine over the 1yr warranty. i had mine torqued down to i believe 7ft pounds.. i had have to double check what it says on the paper that came with them.
I do not have pics yet being that Im at college, and left my car back home. ill post hopefully in a few weeks what the damage was. Alright ill look into TODA and see what other people say.
If you want an idea look at this. this is pretty much what happened to me..https://honda-tech.com/forums/showthread.php?t=2661164 other then the fact he got his replaced and ive had mine over the 1yr warranty. i had mine torqued down to i believe 7ft pounds.. i had have to double check what it says on the paper that came with them.
I'm with N3V3R on this one. I've only used TODA RACING Gears on my builds. They're more expensive, but to me, its worth it. There are others too.
Good luck.
Those should be torqued to about 41ft/lbs per the manual on the VTEC head, and an impact gun should not have been used for the bolts from the gear to the camshaft. The smaller adjutment bolts should be about 7-9ft/lbs on average.
Good luck.
Good luck.
no one does this but can you use stock cam gears on aftermarket cams? i know you can but no one does it just simply because you cant dial them in. the reason why i ask is because ive notice with gsc cams most of the builds i read here, most if not all of the people dial them in to zero. if thats the case wouldnt the stock be a better choice?
Weird...I know BDL uses ARP bolts. At some point they upgraded their bolts from 1/4" to 5/16". Maybe that's why? I was going to suggest BDL or Golden Eagle. I've never heard anyone refer to them as junk before.
What makes Toda so special, other than being JDM?
Pro1s don't cause "backpressure" like you think. Unless you're running some blox or Neukin log manifold. Even then, that's not as likely.
*BUZZZZ* Wrong again, thank you for playing
Had those manifolds 13 years ago. That manifold is not a backpressure issue for even something over 55lbs/min. And a 20g is 44lbs/min while an 18g is 41lbs/min on the Garrett turbine housing and exhaust wheel.
Pro1s ON a Greddy Manifold with a small 18G, that's a different story altogether. but it wouldn't be from backpressure at the manifold, it would be at the turbine.
do you know have the flow ratings or know where the flow ratings are for the greddy mani by chance?
Who is Mr Robot?
I know plenty of people that run gears on stock cams because of the bling factor but on big aftermarket cams they are a basic necessity to the proper tuning of the car
Really?! wow I thought that was my main cutback.. ive been told alot that my manifold is where ill choke out first other then the downpipe which is now 3". From my understanding i thought that was were my problem was. I mean i still knew my Turbo wasn't gonna do a great deal i just thought my mani would of been the bigger picture. thanks i didn't know that.
Its the combination that can cause problems. Not just one item.
No manifold has "flow ratings" unless it was from an outside independent facility, and even then it depends upon the turbine housing turbine exhaust wheel, boost level, etc. (from something over 15 years old in use) I've got DSM and Evolution guys on the same configuration, material and even larger turbo size.. No "backpressure issue" at about 400whp. After that, this is where the turbine exhaust housing, wheel, etc come into play for lower efficiency with that manifold.
hmm..
Cam gears are nothing to play with. The cheaper (ebay) ones are found to have sharper edges due to the way they are made, i'm assuming the cheaply made ones dont have the edges shaved down like "real" gears do.
Also, I normally and only recommend Gears like Golden Eagle or Whitfield gears because they have the ARP bolts which are thicker and longer, and also their markets are far more accurate.. My two cents.
Most with Skunk2 Gears replace the bolts to Grade 8, if they don't overtorque them. I've personally never seen them fail, but there's a first for everything that can be witnessed.
Toda Racing uses Grade 8 already, but going with Whitfield would be a nice choice as it already comes with the bolts you'd like for security.
Whole little description about them.
http://www.hondatuningmagazine.com/t.../photo_02.html
I just called to double check because i do remember before i didn't see what the bolts were made out of. I just got off the phone with one of there representative and he said he doesn't know what they are made out of.. he said there "little steel allen bolt keys" he didn't know the grade of the bolts.. he said steel or aluminum. so idk. i never was able to figure it out.
Well, we just so happened to have a set come through the shop. It is the newer design with the gray box instead of the black box. I am not that good with cameras (back in my day we had drafting classes) and couldn't get the damn thing to focus correctly for the shots. With that being said if you look you can see the edges of the outside ring have been beveled, the bolts are plenty long enough without even crushing the split ring lock washer, the fasteners are some type of plated ferrous metal, and the hardware is stamped LH - 12.9 on the heads of the cap screws. Instructions still lacking, although it gives you an "Owners Kit" that holds a useless picture book of ricers and a 12 month "warranty" card.
