Transmission & Drivetrain Gearboxes, Differentials, Clutches
Wavetrac Or Quaife Or Mfactory
Old Apr 26, 2013 | 04:59 PM
CaliforniaDad's Avatar
No-Traction = Fun
Default Wavetrac Or Quaife Or Mfactory
I'm about to pull the trigger on a better LSD than currently used in my Sedan.
Car is my daily driver.
500+whp 346ft tq
Comments? Questions? Concerns?
Thanks!!
Old Apr 26, 2013 | 05:22 PM
Aquafina's Avatar
Default Re: Wavetrac Or Quaife Or Mfactory
MFactory. Stronger, lighter, less expensive, optional Stage 1 upgrade for more aggressive cornering.
Old Apr 26, 2013 | 09:15 PM
Charlie Moua's Avatar
mfactory right hurrrr.
Old Apr 26, 2013 | 09:23 PM
doood's Avatar
been there done that
Well over 20k daily driven miles on my mFactory. Works just as well as the first day I put it in.
In the end, all three are great choices. Just depends on how much you want to spend.
Old Apr 26, 2013 | 10:06 PM
No-Traction = Fun
Okay Thanks for the input. What oil is preferred? Torco MTF?
Old Apr 26, 2013 | 10:16 PM
Aquafina's Avatar
For 500+whp, Torco RTF.
Old Apr 26, 2013 | 10:19 PM
Black R's Avatar
25 Year Member
What does that do?
Old Apr 27, 2013 | 03:56 PM
No-Traction = Fun
Man that RTF is $$$$$$$$
Old Apr 27, 2013 | 06:39 PM
Aquafina's Avatar
Originally Posted by Black R
What does that do?
The standard bias ratio is 2.1:1 (same as the Quaife). The Stage 1 upgrade changes it to a 2.5:1 bias ratio. It will transfer power more aggressively (the car will be more point, gas, and go than with the standard LSD).
Old Apr 30, 2013 | 03:51 AM
rd91sib18c5r's Avatar
Is this your car?
Old Apr 30, 2013 | 04:07 AM
MR.johnson's Avatar
mfactory and rtf here! love them both
Old Apr 30, 2013 | 07:52 AM
No-Traction = Fun
Originally Posted by rd91sib18c5r
http://youtu.be/jfVcOWqojXc
Is this your car?
Yes that was on my old setup. 475whp. Wow I forgot what my old tan interior looked like. Its all black/charcoal suede now. I fabricated the 2009 civic SI sedan interior in as well.
Old Apr 30, 2013 | 07:53 AM
No-Traction = Fun
Can't wait to see the difference between my OBX lSD and the Mfactory unit.
Old May 6, 2013 | 05:43 PM
blackeg's Avatar
i went from obx to mfactory lsd. one of the best decisions i ever made. its holding up just fine at very similar power numbers to yours. wish i could say the same for my 3rd gear syncro...
Old May 6, 2013 | 06:11 PM
No-Traction = Fun
Good news, could you actual tell the difference between the two?
Old May 10, 2013 | 12:23 PM
DA 4 Lyfe's Avatar
3 years strong with my Quaife LSD while running Redline lightweight shockproof with a stock GSR trans
Old May 10, 2013 | 10:41 PM
f20b jones's Avatar
I have the MFactory with stage one upgrade. I had the obx and there is a big difference. I never had a problem with the obx it worked fine just no were near as good as the MFactory with stage one up grade.
Old May 31, 2013 | 02:18 PM
peaceable's Avatar
Could you qualify the difference please?
Old Jun 2, 2013 | 07:51 AM
No-Traction = Fun
The Mfactory unit is working great! I just feels better than the OBX, notice a difference in the turns.
Old Jun 2, 2013 | 08:45 AM
David @ Synchrotech's Avatar
Glad to hear it!
Old Jun 2, 2013 | 03:53 PM
SPOOLINmatt's Avatar
you really cant go wrong with any of the above choices. I've been beating the **** out of my wavetrac for 3 years now.
Old Jun 2, 2013 | 04:06 PM
Black R's Avatar
25 Year Member
After checking out the proprietary design of the wavetrac, I'm kinda sold on it.
I've had a couple instances where one drive wheel came completely off the ground and I then had no traction at all.
It appears the wavetrac wouldn't have had the same issue.
Old Jun 2, 2013 | 06:16 PM
peaceable's Avatar
Their sight's pretty clear on that. That's the type of technical "qualifier" that I was looking for. Their lifetime use/wear warranty (even under explicit race use) is pretty impressive too - assuming that their company isn't debt margined into near future oblivion.
Old Jul 14, 2013 | 01:26 AM
peaceable's Avatar
I looked at the ATS stuff and found the carbon fiber units to be interesting, kinda pricy, but very interesting.
Old Jul 15, 2013 | 10:04 AM
No-Traction = Fun
******UPDATE*****
My Mfactory unit going strong!!! Feels like everything is broken in and is working better than first installed!!!
