95mm crank gsr block - common to notch?
Old Apr 26, 2013 | 03:17 PM
TimKennard's Avatar
Default 95mm crank gsr block - common to notch?
is it common to have to notch a ge sleeved gsr block when running a crower 95mm crank? manley ultralight rods in ls length, custom wiseco pistons. everything looks fine and appears to be alot of room around the rod by the bottom of the sleeves. just curious if most have to notch. thanks
Old Apr 26, 2013 | 08:08 PM
PyroProblem's Avatar
Default Re: 95mm crank gsr block - common to notch?
Yes. It is also common to notch the 92mm cranks. I had to notch with a 92mm crank as well. I clearanced mine to about .200" iirc..
Old Apr 27, 2013 | 04:35 AM
B23-Vtec's Avatar
My 95mm I didn't have to but my 98mm I had to a lot had to notch the sleeves and the side walls of the block.
Old Apr 27, 2013 | 04:56 AM
98vtec's Avatar
moderator emeritus
The size of the rod is going to play a large role in this, not just the stroke. Not all rods are the same width.
Old Apr 27, 2013 | 10:43 AM
TimKennard's Avatar
ok makes sense, thanks for the input. there seems to be a ton of room. i'll double check and measure but i think its fine.
Old Apr 27, 2013 | 12:15 PM
True. I am using Eagles and although they would not physically contact when rotating the engine by hand, the rods were just baaarely getting by without contact. It was close enough I felt notching was a good idea.
patrick4588
Oct 18, 2007 12:33 PM
integra6650
Oct 9, 2003 07:18 AM
