98 GSR HELP!!
Old Apr 26, 2013 | 05:30 AM
griff12's Avatar
Default 98 GSR HELP!!
So yesterday I changed my alt belt, oil and fuel filter. While changing the fuel filter, unintentionally hit the positive terminal and threw sparks. Thought nothing of it. Go to start the car, dash lights up, everything good. Even reset the maintenance light. Go to turn it over and everything went black like there was no battery. Played with the terminals and nothing. Then on it's own while the key was in "on" Everything came back on and it started up. Has done it two more times since. Any ideas on what it could be???
Old Apr 26, 2013 | 06:06 AM
m4xwellmurd3r's Avatar
sounds like you either have a bad ground or a bad hot side. my vote is on a bad hot side. im suprised you didnt blow the fuse for the altenator. check the fuse and wiring to make sure nothing is burnt and everything is secure
Posted from Honda-tech.com App for Android
Old Apr 26, 2013 | 06:35 AM
griff12's Avatar
Default Re: 98 GSR HELP!!
I'll have to check. I was surprised i didn't also. That was my first thought when it happened. Other thing i noticed was while driving the radio would randomly turn off then instantly back on... Anyone else?
Old Apr 26, 2013 | 11:37 AM
fcm's Avatar
fcm
Old Fart
Check/redo the main grounds, bhatt. to chassis and chassis to engine,
I would also check the main fuses in the engine bay fuse box, make sure they are tight. 94
Jaxis
Oct 1, 2014 02:09 PM
fc3sfrank
13
Sep 4, 2010 08:02 PM
JDM_CRX_PLEASE
21
Jan 16, 2008 02:21 AM
yee SERIOUS
14
Nov 12, 2006 01:30 PM
stareatsun
Mar 19, 2005 08:32 PM
