Transmission & Drivetrain Gearboxes, Differentials, Clutches
typical b16a 3rd gear grind question
Old Apr 25, 2013 | 09:50 AM
RanCRX's Avatar
Default typical b16a 3rd gear grind question
Hello,
My 3rd just started to scratch a little bit before going into gear at all rpms. I'm just wondering if the gear is still good enough to replace the 3rd/4th sleeve and replace all synchros with the carbon ones. It just started to grind and I stopped driving it since. I just dont want to spend money on the tranny if the third gears teeth are effected.
Any help or opinions gladly appreciated.
Old Apr 25, 2013 | 01:41 PM
Gearspeed-Performance's Avatar
Default Re: typical b16a 3rd gear grind question
We wont know if 3rd gear is still good untill you open it and look. Sounds like you need a sleeve set minimum. I would open it and examine it closely, then buy parts from that point.
Old Apr 26, 2013 | 08:12 AM
RanCRX's Avatar
When I do take it out, I'll post a pic on it and see what you think. Probably not till June, but I'll update this topic. Thanks!
Garage786
Dec 5, 2008 09:15 AM
iBrandon
Aug 23, 2007 12:17 AM
snowblind7x
Jan 10, 2007 11:13 AM
HondaRcB
Nov 24, 2006 11:41 AM
7rrivera7
Dec 3, 2002 06:08 AM
