Help: Civic EG Si, Blower motor not working
Old Apr 25, 2013 | 05:02 AM
PaChiLa Leader's Avatar
Icon6 Help: Civic EG Si, Blower motor not working
HI guys,
my blower fan/motor was working fine till last night.
While driving, the fan shuts off and i couldn't turn it back on again.
its not blowing anything right now
i took the resistor and the blower out, but how do i test it?
the resistor looks fine but is there a way to test out the blower before i go on and replace the resistor? i checked the fuse inside the car and since it is the same fuse for the rear defroster and it does turn on so i figure the fuse is still good.
what are the steps to check in order to narrow down the problem and get it working again?
thanks guys~
Old Apr 25, 2013 | 05:08 AM
speedooo's Avatar
Default Re: Help: Civic EG Si, Blower motor not working
If the resistor is bad the blower will work on full power. If the blower is bad it will not work at all.
Old Apr 25, 2013 | 06:31 AM
sleepyaccord96's Avatar
run jump leads to a 12v battery and see if the blower will run. if it does not then your blower motor has gone poo.
Old Apr 26, 2013 | 12:19 AM
Thanks for the reply guys.
Ive inspected everything and turned out to be a bad fuse from the engine bay.
the fuse looks fine physically but guess over time it breaks figured it has been 21 years so... LOL..
Thank you for all the inputs.
Cheers
jesiaczek
Nov 7, 2011 05:58 PM
jwh1276
Nov 25, 2009 08:50 AM
lopes316
Dec 13, 2008 02:43 PM
Arsenal
Dec 14, 2005 11:16 AM
revvin9k
Jan 23, 2005 04:56 PM
