turbo lamp
Old Apr 23, 2013 | 11:04 PM
Crazy_SI_T's Avatar
Default turbo lamp
Currently inthe process of making a turbo out of a torn apart turbo. Only thing is I'm not really sure what type of to use that would be ableto hold the weight ofthe section. Here is one I am going off of. http://hooniverse.com/wp-content/upl...Turbo-Lamp.jpg
Sorry if this is the wrong sanction to post this.
Old Apr 24, 2013 | 04:54 AM
HellaFab's Avatar
Default Re: turbo lamp
going by how sturdy most house lamps are, you would be fine with some 1/8" solid rod bent up to do this with some flanges to weld to.
the biggest part of it all will be making sure that its balanced enough on the base not to fall over.
Old Apr 24, 2013 | 08:40 AM
PhilStubbs's Avatar
I would use tubing of some sort to hide the wiring. 3/4 steel tube painted would be cool. I have been planning something similar myself
Old Apr 24, 2013 | 07:00 PM
Hidenplanvew's Avatar
thats pretty freaking cool
Old Apr 24, 2013 | 10:30 PM
Crazy_SI_T's Avatar
The only issue I can see for myself is I don't have a welder. Any ideas the ? Lol. Going to home depot to get some steel rod.
Old Apr 24, 2013 | 10:32 PM
Discosteak's Avatar
buy or borrow a welder
Old Apr 25, 2013 | 06:14 AM
PhilStubbs's Avatar
Lol, really no options if you can't weld. Do you have a drill along with a tap and die set? Lol
Old Apr 25, 2013 | 08:19 AM
Crazy_SI_T's Avatar
Why would I need that? Was planning on using the existing bolt holes if necessary
Old Apr 25, 2013 | 11:48 AM
PhilStubbs's Avatar
I'm a pretty handy fabricator, but I can't figure out any way to make that without welding or using a tap to thread holes
Old Apr 25, 2013 | 03:51 PM
Crazy_SI_T's Avatar
What I figured I'd do is buy some new bolts that would work with the current threaded holes on the different sections, and bend the bar around and just tac it to the bolts. Thoughts?
Old Apr 25, 2013 | 04:10 PM
SovXietday's Avatar
God damn I'm doing this right fricken now, have all the parts and everything lol.
Old Apr 25, 2013 | 04:13 PM
Schister66's Avatar
Man U FTW
I want one...the filter as a lamp shade is brilliant
Old Jun 20, 2013 | 07:46 AM
Crazy_SI_T's Avatar
been busy but this is what I have so far, there has been NO welding, and the brackets and bolts all come from the turbo. that rod was a BI*** to bend. lol, next is to pick up a filter and wire in the lamp.
Enjoy!!
Old Jun 20, 2013 | 09:05 AM
SovXietday's Avatar
Yeah, could have used some welding to make it look nicer.
I'll try to finish mine up tonight and post it to give you an idea with what I did.
Old Jun 20, 2013 | 09:32 AM
Charlie Moua's Avatar
this is now on my list of car stuf to buy.... maybe after some 2150cc injectors. lol
at work my anti-stress reliever is a t25 turbo... i just try to spin the turbin as fast as i can by hand... lol
Old Jun 20, 2013 | 09:36 AM
Crazy_SI_T's Avatar
ya but I don't have a welder so I gotta work with what I got,
Old Jun 20, 2013 | 11:54 AM
grumblemarc's Avatar
The Grumpiest
I would have threaded the end of that rod and stuck it in one of those six bolt holes in the housing and one end into the cartridge. Then done another rod the same way from the cartridge to the top piece.
Old Jun 20, 2013 | 04:03 PM
jimbo slice's Avatar
I like that idea ^^
Todallybuilt
Feb 27, 2018 04:19 AM
Blindstuff
Jul 7, 2003 03:55 PM
TheSwift1
Sep 6, 2002 10:49 PM
