Turbo Choice for 300WH ( Pics Inside )
Old Apr 23, 2013 | 08:28 PM
lowresolution's Avatar
Default Turbo Choice for 300WH ( Pics Inside )
Hi ,
I am running a built D16Z6 ( forged block / Stock head ) and looking for a turbo for quick spooling / street fun .
I have narrowed down to these two turbo`s which a friend of mine is selling . I am only looking for 300 or so whp out of my car .
The 1st one is from an EVO 8 MR
The 2nd one is the T04E ( no other info , except that the friend was using it on his B16 , and this spooled on a rich tune on his b16 at 3200RPMs .
Can someone please advice me out of these two which should i be choosing for my goals and what estimated spool times should i be expecting out of these two ?
Old Apr 23, 2013 | 11:13 PM
Default Re: Turbo Choice for 300WH ( Pics Inside )
Anyone ?
Old Apr 24, 2013 | 12:17 AM
yungkhmer's Avatar
is that a ebay t04e turbo?
Old Apr 24, 2013 | 01:59 AM
No. I am sure its not the ebay one
Old Apr 24, 2013 | 03:06 AM
mrbigg9032's Avatar
Pretty sure that second one is a turbocharger brand turbocharger aka eBay crap. Stick with the evo turbo it will meet your power goals and be more reliable
Old Apr 24, 2013 | 04:30 PM
Schister66's Avatar
Man U FTW
The tag on the compressor housing would lead me to believe it IS an eBay turbo.
Personally, I would use the Evo 8 16g...the problem with this turbo is that it requires a proprietary divided flange and isn't a common option, but it does exist
Old Apr 24, 2013 | 05:07 PM
SiRCiviC94's Avatar
Spooling so low just wastes gas
Old Apr 24, 2013 | 05:24 PM
Schister66's Avatar
Man U FTW
Gas usage is a function of power creation...if you're worried about losing gas mileage, buy a Prius/Insight. Personally, i think the biggest problem with many Honda turbo setups is that most use grossly oversized turbos...in this case the Evo 16g is about the perfect size for his goals. Dont be afraid of having a useful powerband
Old Apr 24, 2013 | 06:08 PM
Louie Louie's Avatar
This guys got it. My power goals are around 300. Wish I would have gone with a t28 instead of the t3/t4.
Old Apr 24, 2013 | 07:51 PM
Thanks guys for the responses . Actually the problem is that the turbo i am using its quite laggy for my taste .
I dunno much about it exacept that its a turbonetics unit with a garret housing . It spools at around 5-5.5k with vtec . Which is way too laggy for me . Here are some pics of the turbo i am currently using
Old Apr 24, 2013 | 08:27 PM
TheShodan's Avatar
Moderator
Use the Evo 8 MR, get rid of the top mount manifold. create a custom one for the Evolution twin scroll, (That is not in any way a top mount.) assemble, tune, and enjoy.
Old Apr 24, 2013 | 11:56 PM
Thanks for the suggestion, i alway like your responses on this site . Changing manifold is a costly one for me , since i recently had this manifold made
Can`t i use my existing mani ? , also is the turbo which i am currently using really to big ??. The car is street tuned and runs fine , its just that in 3rd gear there is lag which i don`t like , as in at the start of the 3rd gear , the boost drops to like 13-14 then goes over to the target boost i.e 19 ( on which the car is tuned one ) . Also at launch control , with antilag i was making only 1 psi of boost , i went back to the tuner , and he activated VTEC on launch , as a result of that , not its making 5-6 psi of boost at launch.I have neptune rtp
I just got into this debate to change the turbine to a smaller one coz i lost pretty badly to a K20/K24 all motor civic ,that car had all the world invested into it. I was hoping to atleast stand a chance against it at, he got me by 3-4 car lengths . Do i really need to change my turbo :O, or a d16 runs like this ? , i am a confused as hell bloke .
sorry for the bombardment of questions
Old Apr 25, 2013 | 07:25 AM
project dc2's Avatar
thats an e bay t4 turbocharger. stick with the OEM EVO 8 turbo and it should get you a pretty good amount of power
Old Apr 25, 2013 | 08:05 AM
TheShodan's Avatar
Moderator
Yes, D16s run like that. changing housings won't help that much. You took a turbo that was made for higher end power, on an engine platform with a very inefficient head design, and then piled on top of all of that, had a top mount exhaust manifold made that essentially eliminates all of the characteristics you were looking for in an effort to "show off" the turbo. (If you really knew what that type of manifold is used for, you'd have never done it for that engine platform, which is why I say this. )
So, yeah.. even a T28 wouldn't have held against a Evolution MR turbocharger with that size of hot side. you'd have been even worse off than now. Time to learn from this error, and rebuild if you plan to keep using this D-series engine.
Old Apr 25, 2013 | 08:35 AM
No sir , i had no plans to show off actually i was in favor of a ramhorn manifold , but my tuner who is a very good friend kept insisting to go with a top mount manifold setup. Also the turbo was there when i bought the car , that is why i am willing to change it up .
Thanks for the advice , i will look into getting the manifold change and perhaps go with a smaller turbo.
Old Apr 25, 2013 | 09:23 AM
Schister66's Avatar
Man U FTW
^^If you want better spool, this is step 1.
Old Apr 25, 2013 | 09:49 AM
TheShodan's Avatar
Moderator
Ah yes, the "my tuner recommended it" case. That advice can really be 50/50 depending upon their experiences.
Arseezy
Sep 4, 2011 07:22 PM
092eg6
Jan 11, 2010 12:29 PM
mikej94civex
Jan 6, 2010 04:35 PM
092eg6
Jan 3, 2010 05:42 PM
rice is nice
May 11, 2008 09:17 PM
