strut bar help!!!
Old Apr 23, 2013 | 04:04 PM
termite1r's Avatar
Default strut bar help!!!
ok I know this is a really noob question but if I want to add strut bars to my civic do I need to also install lower control arm bars?? just curious
Old Apr 23, 2013 | 04:06 PM
grumblemarc's Avatar
The Grumpiest
Default Re: strut bar help!!!
What do you need strut bars (that do nothing) for?
Old Apr 23, 2013 | 04:17 PM
termite1r's Avatar
well I was just wondering if I would need anything in case I acquired strut bars. Most likely I would get sway bars though.
Old Apr 23, 2013 | 04:20 PM
Ryan96GSR's Avatar
Non-vtec civics often have clearance issues with the stock airbox.
If you have the vtec model you should be fine.
Old Apr 23, 2013 | 04:32 PM
mikekh10a's Avatar
no you don't need to install anything else to go with the strut bars...it's just to reduce flex in the chassis. most strut bars out there are crap though, so pick carefully..
Old Apr 23, 2013 | 04:37 PM
termite1r's Avatar
cool thanks everyone for the feed back
if I got strut bars I was thinking DC or Skunk2
Old Apr 23, 2013 | 04:50 PM
EsotericImage's Avatar
Retired Moderator
look for something solid that doesnt use a bolt creating a pivot point.
Old Apr 24, 2013 | 12:38 AM
SozeHuck's Avatar
I got a type r front strut bar on pure whim and it significantly helped my crappy stock set up. Buy 4 solid bolts, washers and lock washers, 8mm or bigger and your golden. Or save up for a rear sway bar and do WAY more for your handling. In hindsight that woulda been far smarter.
Old Apr 24, 2013 | 01:03 AM
jbpnoman's Avatar
This is the most important part. If it has a pivot point, it's just short of worthless. The whole point of a strut tower bar is to prevent flex. A unit with pivot points allows flex, it just controls it a little better.
The best option for a strut tower bar is a 3 point, similar to what Password JDM sells.
Old Apr 24, 2013 | 09:17 PM
termite1r's Avatar
Awesome thank you everyone for the help!
ima look into the three point tower strut bar and the rear sway bar.
maal15
Nov 7, 2008 03:41 PM
androO
Nov 22, 2007 10:15 AM
ludecrasy87
Feb 24, 2007 09:43 AM
halcyon026
Honda Civic (2001 - 2005)
Mar 30, 2006 05:04 PM
kenjief8
Dec 30, 2004 06:59 AM
